How to remove delsol door panel?
I removed many civic door panels, but I have trouble with this Delsol door panel.
Do you remove the power window switches and the handle? If so how can I do that?
Thanks
Thanks
Leave the switches in and unplug them once the panel is somewhat loose. The handle itself you have to twist just a little bit and let it slip through the panel. Does that help you any?
You don't need to pull it off to remove the panel. There should be a screw/bolt behind it, one screw behind the upper handle/by the lock and one on the edge of the panel closest to the A pillar. The rest should be clips along the edge of the panel. The lower handle can't be removed until you see the back side of the panel...if you can even do it then, I can't remember.
*Boostwerks*
Sep 13, 2002 08:52 AM
