auto to stick conversion on ef..what parts needed?
as the titles says. I asked this question before but my stupid *** forgot to save it and i can't find it no more
anyway, i got the follow parts
pedals
shift linkage
bolster
what else do i need?
Jeff-
pedals
shift linkage
bolster
Jeff-
Bolster? You also need the bushing that mounts the shift linkage to the car. I had to drill one hole to mount the linkage because the two holes for the auto gear selector are farther apart than a manual. This is a very easy swap, just keep in mind that you have to remove your dash and lower your steering column to install the pedals.
You also need a clutch cable for whatever tranny you are using.
I didnt have much trouble pulling this swap off, because I removed the engine so it made it easy to remove all the extra tranny cooling lines etc.
i have the clutch cable as well. got the bushings too. you guys have any instructions somewhere that shows exactly how to do it?
the engine is out of the car and i have no problem removing the dash
Jeff-
Jeff-
JDM-EJ1
10
Oct 2, 2004 02:55 PM
