Advanceing the Timeing...How?
How can I advance the timing on my 92 4ws h23a? Its pretty much stock as far as engine mods go, so I just want to advance it one or two degrees. How can I do this? Pictures would be even better
Also, how much of a gain would I notice?
thanks!
Also, how much of a gain would I notice?thanks!
Honda does NOT have it in the best place for performance from the factory; it's set for max. reliability. Bump the timing up 3-4 degrees and you'll feel a noticeable increase in low-end torque.
Oh yeah, and to do it, take a razor or sharpie or something and scratch/mark a line across the distributor. This is to know where the stock setting is. Then loosen the three bolts around the distributor cap, and turn it towards the firewall to advance. Then just tighten back up the 3 bolts. Each degree= roughly 1mm of turn
Im sure this sounds dumb, but the distrbituer is the thingie where all the spark plug wires orinate at, correct?
also, about how much would you guys suggest I advance? I was thinking 2.5MM or so. (I always run 93 gas too).
Yes, I agree, if you do not use a higher octane (i use 93 Mobil) your car will be worse off. There will be a ping at idiling and like a flutter inthe rpms. I have my timing advanced to 18 no probs for me (thanks Mike
[Modified by Ludester, 3:52 PM 2/25/2003]
X2BOARD
Jul 2, 2005 09:27 PM
94gsr
Oct 24, 2002 04:15 PM
