Turbo B16A2 map Problem ??
y have make may own turbo kit
and now when i run it's turn on the engine ligth
is Map sensor or ECU ??
if i use Missing Link MAP Bypass Valve i will resolve the problem ???
thanks
thanks
thanks
thanks
I think your asking how to fix your cel now that your gone turbo.
Yes using the missing link will fix your cel problem, oryou can use some check valves between the map sensor and vacuum, thats what i've done for the last 3 years with no problems....
thanks
thanks
FMU?
Bigger injectors?
