turbo B16A2 Map problem ???
y have make may own turbo kit
and now when i run it's turn on the engine ligth
is Map sensor or ECU ??
if i use Missing Link MAP Bypass Valve i will resolve the problem ???
thanks
thanks
Like whoa!!! ok let me see if I get this. Your turbo is building pressure and then you get a CEL Correct. What boost are you running?? Honda map sensors can only handle 8-10 PSI before they go limp mode. If this is your problem you need a missing link, some check valves or a stand alone ECU that uses a 3 bar map sensor (haltech, hondata, etc....)
hi thanks for the attencion
my problem is that i have dome my own kit and i think i forget something
i had run wicth the car at 0.3 bar (+/- 4 psi ) and engine ligth turn on
i think is about map sensor because i see on hondata page that Ecu can only acept 1 libra
what do you think about this
the missing link can resolve my problem ??
[Modified by _VTI-R_, 12:11 AM 2/25/2003]
[Modified by _VTI-R_, 12:12 AM 2/25/2003]
Is your map sensor good?? Test voltage and it all within specs even where it runs into the ECU plug. 1 bar is aprox 15psi (almost positive) so you should be able to run 0.5 bar and have no problems unless there is something else wrong. A missing link may cure your problem, I would suggest some cheep check valves to test that idea before buying a missing link. Check valves that they use with aquarium pumps can you get at any pet shop and are really cheep. Also can try another map sensor if you have a spare. Just a few ideas before you buy something you may not need
if your on a budget you can make a getto missing link , go get 2-3 check valves,t's and a vacuum hose. you can get the check valves at a fish store, petsmart for a few bux
pm me for more details
Unless you have a aftermarket ecu you have to bleed the boost off of the MAP sensor. 2-3 check valves inline with your MAP sensor should work fine. The Honda MAP sensor will read up to 11.8 psi but your stock ecu won't know what to do with it.
if you can i want more details about that ??
mising link or map sensor bypass valves ??
what difrence??
tell me if i use 0.6 bar i will nedd to do any change on ecu or missing link is sufficient ??
[Modified by _VTI-R_, 10:28 PM 2/28/2003]
what difrence??
