Honda S2000 Honda S2000
Offset required for a 265mm wide rear tire on a S2K?
Old Feb 24, 2003 | 07:06 AM
quick108's Avatar
Default Offset required for a 265mm wide rear tire on a S2K?
I'm looking at 17 inch:
Mugen MF10 (+59 offset)
or
Volk SE37K (+45 offset)
Will either of these work?
Old Feb 25, 2003 | 12:36 PM
jerrypeterson's Avatar
Default Re: Offset required for a 265mm wide rear tire on a S2K? (quick108)
The MF10 is a really tight fit but somehow works.
ZERO chance the SE37K's will fit in that offset.
Old Feb 25, 2003 | 01:20 PM
J'sAP1's Avatar
Default Re: Offset required for a 265mm wide rear tire on a S2K? (jerrypeterson)
You can always roll your fenders and they will work. I have Spoon SW388s all around at a +35 front and +45 rear and tuck just fine(still minor rubbing in the front). For normal application Jerry Peterson is right the Mugens will fit (close) and there is no chance for the Volks.
Old Feb 25, 2003 | 07:15 PM
ccarnel's Avatar
Default Re: Offset required for a 265mm wide rear tire on a S2K? (SpoonS2000)
I have 265 rear width tires in the Brigdgestone s02's. My rear offset is +73 mm and its cutting it close to fit.
Old Feb 26, 2003 | 08:20 AM
quick108's Avatar
Default Re: Offset required for a 265mm wide rear tire on a S2K? (ccarnel)
Ccarnel:
What wheels have a 73mm offset? Are you "cutting it close" on the inside or outside of the fender well?
SpoonS2000:
Do you have 265's on your 16" SW388's?
JerryPeterson:
I believe the SE37 has more -offset then the SW388. You don't think they will work?
Do you guys have any pictures? I just picked up an S2 last night and I'm contemplating on the proper offset for a wide tire.
Old Mar 3, 2003 | 06:44 AM
quick108's Avatar
ttt
Old Mar 3, 2003 | 05:18 PM
ccarnel's Avatar
Sorry been covered up with exams lately. They are custom 3 pc kinesis wheels. The fit is close on the outside but they do not rub at all.
Old Mar 6, 2003 | 09:43 AM
PROFILES2000's Avatar
gotta love kinesis wheels
Old Mar 6, 2003 | 01:00 PM
.RJ's Avatar
.RJ
You asked:
But this was already posted:
FWIW.
Old Mar 6, 2003 | 01:59 PM
quick108's Avatar
Default Re: Offset required for a 265mm wide rear tire on a S2K? (.RJ)
To clarify, JerryPeterson's opinion is that 45 is not enough offset for a 265mm whereas SPOONS2000 says 45 offset works. I know it has to be borderline but I wanted to know if Jerry has had a bad experience with a 45offset/265mm tire on a S2000.-Thanks!
Old Mar 7, 2003 | 05:50 PM
johnny--2k's Avatar
my motegi's in a 40 offset fit just fine. 245 rear 225 front tire sizes (17 inch)
and sorry, i know the pic is HUGE, but im at work now, so cant do much about it
maxogsr
Jul 16, 2008 04:05 PM
s2khic
Honda S2000
16
Sep 29, 2005 01:54 PM
GEN2TEG
Honda S2000
Sep 5, 2005 12:57 AM
sebmour jdm
Honda S2000
11
May 27, 2005 02:27 PM
t o m
13
Jan 2, 2005 05:03 PM
