Honda S2000 Honda S2000
offset for wheels???? please help
Old May 26, 2005 | 08:50 AM
sebmour jdm's Avatar
Default offset for wheels???? please help
OKi so i want to get a set of wheels for my S2k.
I am wondering if i would still have a could traction with 16X7 45 offset at the front and 17X8 at rear.
I am also wondering wich offset do i need for the rear set?
Thanx guys and have a nice day in vtec land
Old May 26, 2005 | 09:11 AM
cmdr430's Avatar
Default Re: offset for wheels???? please help (sebmour jdm)
what wheels are you looking to purchase?
Old May 26, 2005 | 09:53 AM
Default Re: offset for wheels???? please help (cmdr430)
Those it really matter?
They have tehm in 48 mm offset at rear. Would it fit properly?
205/55 16 front and 225/45 17 rear.
Old May 26, 2005 | 09:55 AM
Troy's Avatar
I had NSX rims which were
16x7 +45 (205/55/16)
17x8.5 +55 (245/40/17)
Old May 26, 2005 | 09:59 AM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sebmour jdm &raquo;</TD></TR><TR><TD CLASS="quote">Those it really matter?
205/55 16 front and 225/45 17 rear.</TD></TR></TABLE>
yes it matters..... each wheel company is different as to which offset will fit the s2k....
for example, i had 17*7 front 17*8 rear work emotions, 47 offset front and rear.......
also, that rear tire size is to narrow......
you should be able to run a 245 *40 rear which is what the 04- come with.....
Old May 26, 2005 | 07:51 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
I have a similar question so I'm not going to start a new topic. I going to buy some Advan RGII's F-17x7.5 and R17x8.5. What offset will I need, and what tire sizes should I run? I want the widest possible tires without rubbing and maintaining safety.
F-225/45/17 ???
R-255/45/17 ???
Modified by NAallTheWAY at 9:20 PM 5/26/2005
Old May 27, 2005 | 12:35 AM
sixsixsix's Avatar
OneWayHighway
Default Re: offset for wheels???? please help (NAallTheWAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY &raquo;</TD></TR><TR><TD CLASS="quote">I have a similar question so I'm not going to start a new topic. I going to buy some Advan RGII's F-17x7.5 and R17x8.5. What offset will I need, and what tire sizes should I run? I want the widest possible tires without rubbing and maintaining safety.
F-225/45/17 ???
R-255/45/17 ???
Modified by NAallTheWAY at 9:20 PM 5/26/2005</TD></TR></TABLE>
Whats the offset on those wheels? List all the offsets offered.
Old May 27, 2005 | 03:45 AM
cmdr430's Avatar
F-225/45/17 ???
R-255/45/17 ???
48 front offset
50 rear offset
you will probably get some rubbing in the rear w/ that size tire....
i had 255 40 on mine and it rubbed on larger bumps....
are you lowered? how much?
Old May 27, 2005 | 07:19 AM
PornStarRacingB16T's Avatar
I'm thinking with those offsets cmdr430 is right and you'd want to run a 255/40 in the rear.
Its a shame that more companies don't make wheels in offsets that are more optimal for this car. I love my 9" wide rears but I'm pretty much stuck with my CE28N's unless I want to go to a two piece wheel like a Work Meister.
Old May 27, 2005 | 09:34 AM
futomame's Avatar
I didn't think the type of wheel really matters.
If you have a 17x8 +55 offset in a Work Emotions wheel, it will be the same size & fitting as a 17x8 +55 in a SSR Comp wheel. The type of wheel shouldn't matter, its only the specs. Or am I misunderstanding something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">
you should be able to run a 245 *40 rear which is what the 04- come with.....</TD></TR></TABLE>
Old May 27, 2005 | 01:06 PM
EFSS153
48 front offset
50 rear offset
I ordered some Espelir springs. I think its a 20/30 mm drop. So would you recommend a 245/45 rear tire?
I called gruppe-s and they said the Advan RGII's for the S2K were a +45 for 17x7.5 front and +50 for 17x8.5 rear.
Old May 27, 2005 | 02:27 PM
speed4tu's Avatar
The offset depends on the width of the wheel. I have 18X8 in the with +51 offset, and 18X9 in the rear with +63. This is a perfect combo.
JjuuN R
Jul 4, 2007 04:08 PM
HeavyFoot_Tony
Honda S2000
Dec 3, 2005 07:38 PM
s2khic
Honda S2000
16
Sep 29, 2005 01:54 PM
quick108
Honda S2000
10
Mar 7, 2003 05:50 PM
MikeD
Jul 24, 2001 09:05 AM
Top
Follow Us
