LSD: how bad did I screw it up?
Old Feb 24, 2003 | 05:40 AM
Jack Black's Avatar
Default LSD: how bad did I screw it up?
I ran off the side of the road into a very deep pothole at about 50 mph this morning. This caused the right front tire to blow out. When I pulled over and checked it, I didn't see anything wrong with the tire. It looked like the bead had come loose and let all the air out, so I figured I could reinflate it.
So I put the spare on the front and drove to the nearest gas station, which was about 2 miles away, going 40 mph or less the whole way.
I know you aren't supposed to run the spare on front because of the LSD, but I wasn't thinking at the time. How bad would 2 miles at 40 or less screw it up?
Oh, in case you're wondering, the tire didn't reinflate. Turns out the sidewall got cut. But I did at least have sense enough to swap the spare onto the back once I got to the gas station.
Old Feb 24, 2003 | 08:48 AM
Jack Black's Avatar
Default Re: LSD: how bad did I screw it up? (Agent Smith)
Anyone? Anyone? Bueller? Bueller?
Old Feb 24, 2003 | 08:50 AM
nfn15037's Avatar
I dont think it will really hurt a gear type LSD. That warning is more appropriate with a clutch style LSD, which will get a lot of wear from differing tire sizes, while a gear type LSD should be fine.
Old Feb 24, 2003 | 08:55 AM
Warren's Avatar
Wrong-Way Wang
You didn't bust it. TORSEN diffs are quite stout. You'll know if it's busted. It either works or it doesn't, unlike a clutch lsd.
Warren
Old Feb 24, 2003 | 09:03 AM
Jack Black's Avatar
Default Re: LSD: how bad did I screw it up? (Warren)
Cool. I was hoping that the worst that would happen would be accelerated wear since it's basically like going around a corner the whole time.
Old Feb 24, 2003 | 12:26 PM
sgT's Avatar
sgT
id check for bent suspension arms
Old Feb 24, 2003 | 12:31 PM
reefer_bob's Avatar
Default Re: LSD: how bad did I screw it up? (sgT)
My thoughts exactly... and check the wheel to make sure it's not tweaked too...
Old Feb 24, 2003 | 12:37 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: LSD: how bad did I screw it up? (reefer_bob)
damn Jack, glad you're okay. You just taught me something though....
Old Feb 24, 2003 | 01:19 PM
Jack Black's Avatar
I visually inspected both this morning and didn't see any obvious problems. Also, it drove fine (no noticeable pulling or wobbling) after I swapped the spare onto the back.
I'll have the wheel checked when I get the tire replaced, and I guess an alignment would be a good idea, too.
Old Feb 24, 2003 | 01:25 PM
Jack Black's Avatar
Default Re: LSD: how bad did I screw it up? (RealTypeR)
Yeah, I'm fine. Annoyed, and a couple hundred bucks shorter, but otherwise fine.
Sorry to hear you're thinking about selling the R, man. I hope you realize you're still required to attend expo, though
Old Feb 24, 2003 | 01:29 PM
Jack Black's Avatar
Hmm... the forecast doesn't call for rain... maybe I'll run the race rubber for a couple days... hehehe
Old Feb 24, 2003 | 01:35 PM
Tweakmeister's Avatar
Lift the front up and do "the test"
Rotate one side and see if the other side spins the other way.
Old Feb 24, 2003 | 02:02 PM
itr1244's Avatar
Default Re: LSD: how bad did I screw it up? (Tweakmeister)
It shouldnt be that bad
Old Feb 26, 2003 | 12:14 PM
deepgreengsr's Avatar
Default Re: LSD: how bad did I screw it up? (itr1244)
take the car to a body shop and have them check if the suspension **** is still str8.
they can put it on their body alignment rack and tell you.
Old Feb 26, 2003 | 12:17 PM
nfn15037's Avatar
Default Re: LSD: how bad did I screw it up? (deepgreengsr)
A body shop? Last i checked body shops worked on bodies, not suspension. I would go to an alignment shop, but thats me
Old Feb 26, 2003 | 01:20 PM
OC 335i's Avatar
Default Re: LSD: how bad did I screw it up? (nfn15037)
I think he means the frame.
Old Feb 27, 2003 | 05:29 AM
Jack Black's Avatar
Default Re: LSD: how bad did I screw it up? (MEGA EK)
I got the tires replaced yesterday and also had an alignment done. Like I said before, I had visually inspected the suspension and surrounding bodywork for damage and had found none. I also asked the mechanic to look it over and he saw nothing. Obviously that isn't as accurate as putting it on a frame machine, but there's no indication at the moment that a frame machine is necessary.
Before the alignment, toe was -0.25 L and -0.35 R (in degrees, right side is the one that got hit). That doesn't seem to be too out of whack.
Old Feb 27, 2003 | 08:33 AM
Fuuma0083's Avatar
Also if you haven't taken the chance to check the rims for bents.
Old Feb 27, 2003 | 09:45 AM
TypeR 01 886's Avatar
Very informative post How would you know if the LSD in our cars were bad though??
Old Feb 27, 2003 | 12:28 PM
Petah's Avatar
Default Re: LSD: how bad did I screw it up? (TypeR 01 886)
Sorry to go off topic, but how can you test if your car has a LSD or not? When my shop installed a LSD tranny into my car, they showed that the tranny does infact have a LSD via this method:
The car was on the hoist and the mechanic was turning the drivers side wheel. The passenger side wheel was turning in the opposite direction while he was doing this. The mechanic told me to try and hold the wheel still while he was turning the wheel on his side.....i couldn't! He said this was beause there is a LSD in there....any truth to this?
Old Mar 5, 2003 | 02:17 PM
"I think he means the frame."
At least this guy has a brain.
[Modified by deepgreengsr, 11:18 PM 3/5/2003]
Old Mar 6, 2003 | 09:18 AM
nfn15037's Avatar
Yes, you obvously must. Well your reply was vague and poorly thought out, and how about some punctuation?
lastpunkinline
May 27, 2006 03:56 PM
donton
Apr 7, 2005 08:51 AM
donton
Apr 6, 2005 04:01 PM
Wrath of VTEC
Dec 1, 2003 12:04 AM
kb58
Apr 3, 2002 11:10 AM
