Coolant loss.
Old Feb 23, 2003 | 07:59 PM
Dancing is Forbidden's Avatar
Default Coolant loss.
I have a 92 Cx that I got recently and it has had the problem since. When you fill the radiator up with fluid and get the engine hot, all the fluid goes into the overflow-as it should- but when the engine cools off it is not going back into the radiator-which it SHOULD do- So what do you guys think? It is just all coming out of the overflow tank. ARGH. We have replaced the radiator cap with a 16psi replacement. (is that right? thats what advance auto said). we also bled it at the relief valve, but no bubbles there. UGH. Sorry if this doesnt make sense, but thanks for the input.
Old Feb 23, 2003 | 08:01 PM
sshaikh01's Avatar
Default Re: Coolant loss. (EF9_SiR)
My sister's 94 civic did that.
Her thermostate was gone, i replaced the thermostate, the car ran fine.
Check your thermostate.
Old Feb 23, 2003 | 08:03 PM
97hb's Avatar
Default Re: Coolant loss. (sshaikh01)
Check your thermostat.
Old Feb 23, 2003 | 09:52 PM
Motorhead
Guest
Posts: n/a
thermostat...
Old Feb 23, 2003 | 09:58 PM
projectM's Avatar
im having the same problem and i replaced everything,h20 pump,thermostate,radiator,and radiator cap... and my coolent is still overflowing in the reservoir...i have a blown headgasket and you might wanna check it yours is blown too....
Old Feb 24, 2003 | 07:49 AM
Default Re: Coolant loss. (projectM)
Well i am 99.9% sure it is not the head gasket. And I was thinking that the thermostat is bad, but I guess I will replace that today if I get the time. Thanks guys.
iHEARTMYCiViC
Jan 19, 2010 04:53 PM
94civicex.
Dec 11, 2009 11:03 PM
herrgolf
Jun 27, 2008 02:23 PM
Spoonsinglecam
May 30, 2008 06:11 PM
BoostedGSRBubble
May 26, 2002 02:39 PM
