Behaviors of a blown turbine?
Sounds about right, I some how lost about a 1qrt&1/2 of oil last night. And my idle is really rough. But i get no white/black/nasty smoke out the exhaust or out the breather hole of the head.
[Modified by blu_si, 4:19 PM 2/23/2003]
Well i was just outside having another look around and i noticed that when i start my car, then rev the engine a little, oil seeps out between the manifold and where it bolts to the turbine. Blown turbo?
Sounds like you got oil problems... If you can check inside the compressor housing, if there is oil residue, your fucked... That usually means that oil is leaking in there, and the vacuum preasure pulls the oil through the leaks...
I still am learning about turboes so thats the most advice I can give you...
EDIT: The leaks are usualy cause by failing bearings... The oil seals for the bearings can go bad...
[Modified by 631 Teggy, 1:26 AM 2/24/2003]
yeah i was just gonna get a new one. i don't have time to wait for a rebuilt one to come back. what do you think of this one? https://honda-tech.com/zerothread?id=420954
If it's caused by a clogged oil return, and the turbo is fairly new - less than 40-50K with regular oil changes - you usually don't need a rebuild. Just dissassemble and chip the coking away from the shaft and seals, fix your drain tube, and go... no more smoke.
Ok here is the thing, i'm not getting any smoke. Just a really rough idle and lack of boost(the highest i could boost last night was 3psi).
This happens a lot, just from the turbo being used to much...
chickenandpickles
16
Sep 11, 2005 01:29 PM
sushibug
Jun 10, 2002 11:07 AM
