OT: Would an 8 gallon compresoor suffice?
Old Feb 23, 2003 | 09:37 AM
jaymar88's Avatar
Default OT: Would an 8 gallon compresoor suffice?
I'm thinking about purchasing a compressor and there's an 8 gallon 115 psi compressor for 100 bucks. Would this suffice for most jobs including crank pulley removal? TIA
Old Feb 23, 2003 | 09:44 AM
Ferrell's Avatar
Default Re: OT: Would an 8 gallon compresoor suffice? (jaymar88)
harbor freight eh??
ive considered the same.... id like to know as well..
Old Feb 23, 2003 | 09:51 AM
mickey513's Avatar
me too
Old Feb 23, 2003 | 10:03 AM
sgT's Avatar
sgT
probably not.
volume doesnt mean much. Its all about CFM and most of the time the more
volume, the more cfm. I would recommend at least a 30 gallon compressor.
Old Feb 23, 2003 | 10:14 AM
SlowTeg's Avatar
Default Re: OT: Would an 8 gallon compresoor suffice? (sgT)
Ya.. expect to get at least a 30 gallon if you want to be able to do any serious stuff.. I can't imagine an 8 gallon being good for anything besides running a 3/8" air tool and filling your tires w/ air..
-Mike
Old Feb 24, 2003 | 08:02 AM
jaymar88's Avatar
Default Re: OT: Would an 8 gallon compresoor suffice? (SlowTeg)
Yep. I figured as much. Hey SGT. You know off hand what the torque spec is for the crank pulley? When putting it back on, Should I use any loctite?
Thanks.
Old Feb 24, 2003 | 09:18 AM
92sleepR's Avatar
New User
Ahhh, Good old Harbor Freight.
CFM at a given pressure and the HP of the compressor motor are better specs to look at.
3 hp and over 5 CFM at 90 PSI will do you fine (although it won't be enough to run a really big air wrench)
Another way to look at is is to look at the CFM reguirements of the biggest tool you want to run and see if the compressor meets or exceeds that. You WILL be surprised at how much air some tools need.
I have a 3hp Central Pnumatic compressor from Harbor Freight and its been sufficient to paint three cars so far but it CANT drive big air tools (which pisses me off)
Hope this helps
Mike
Old Feb 24, 2003 | 09:21 AM
Dave-ROR's Avatar
Default Re: OT: Would an 8 gallon compresoor suffice? (92sleepR)
6.2SCRM @ 90PSI is our track/portable compressor. 6.2SCFM isn't ****, I can't imagine the hell of trying to work with a 5SCFM @90 PSI compressor (oh yeah I can, "give me that breaker bar" since I'd be using handtools a lot). 5SCFM with a gun will work for changing wheels though..
Old Feb 24, 2003 | 11:43 AM
jaymar88's Avatar
Default Re: OT: Would an 8 gallon compresoor suffice? (FyrStarter)
What about electric impact wrenches? 240 lbs of trq 7 amps?
Old Feb 24, 2003 | 11:53 AM
sgT's Avatar
sgT
my impact does 550-600 reverse lbft and uses like 7-8 cfm
my 30 gal pushes about 8-9cfm i think.
electric impacts suck, unless its the snap on.... i need to get me one of those
Old Feb 24, 2003 | 11:55 AM
Dave-ROR's Avatar
Nate's snap-on electric one took a **** gotta find out what warranty is on those.
The guns we use are all 550lbft or more of course, soon we will have a 15-16csfm compressor... <eg>
sporkcrx
Aug 11, 2004 10:30 PM
weraider30
Jul 18, 2004 12:27 PM
slowls
Apr 29, 2004 06:44 PM
.cingham
39
Apr 11, 2004 12:05 AM
