red, red/black, or black?
The dimmer switch for the instrument cluster lighting has three wires going out of it: red, red/black, and black? i would like to tap into the wire which leads from dimmer switch to instrument light . Does anyone know which color the wire is? Thanks!
95
civic
95
civic
Im pretty sure that it is possible to make ANY cluster dim. You just have to find the wire that powers the lights and wire that through a dimmer. Any variation in current is going to limit light output = dimmer.
Jon Black
Jon Black
This of course would need to be a wire that is isolated from the parking/interior lights. You can make it work if you have enough skill/experience. Any competent alarm installer can do it for you.
Jon Black
Jon Black
no, that wont work, unless you want every single electrical peice in your car dimming with your cluster.
[Modified by Spoon Hybrid, 5:37 PM 2/23/2003]
Yes it will work. The circuit is one that is in parallel not series. Thats why if your parking light bulbs blow or your interior light bulb blows you still have dash/cluster lights. If you find the right wire, which will be one that plugs into the cluster itself, you can dim it.
Jon Black
Jon Black
If you have a seperate cluster fuse, you should be able to put the dimmer there. If you dont then you will have to wire the dimmer in at the point where the harness attatches to the cluster.
Jon Black
[Modified by Jon Black, 5:45 PM 2/23/2003]
All of those wires are up there. E-Brake, Hatch Open indicator,etc. I used to use the Hatch Open light to do custom alarm installs instead of running a pin switch on the hatch itself. I used to use the E-Brake light wire in Remote Car Starters so they wouldn't attempt to start unless the E-Brake was up on a manual transmission equipped car.
Jon Black
Jon Black
each line of lights have their own switch s..thats why when u dim one switch all the lights on the cluster dim..other interior lights are on another switch and do not dim..for isolated case s a seperate switch will be need d..hook up the red to red *+* and ground the black *-* the black/red is for the dimmer
cklauj207
Oct 7, 2012 05:31 AM
Suck my DX
11
May 12, 2007 01:13 PM
