What are these???(B18C)
1. FPR-fuel pressure regulator?
2. blurry picture?
3. oil sensor? a wire is suppose to go there. i know that is where you tap it for an oil feed for a turbo.
[Modified by Kid1320, 9:12 PM 2/22/2003]
2. blurry picture?
2. blurry picture?
2. blurry picture?
[Modified by hybridvteceg, 12:13 AM 2/23/2003]
sorry about the second pic....
ill give a little description...its under the intake mani and its a black box with a sensor plugged into it....
I'll try to get a better pic in the morning...
also, what vacume line hooks up into the thing in pic 1??
#2 is Intake Air Bypass valve (plastic box) it should have one vacuum line coming
from it hanging around there somewhere...hook that to #1 picture...for # two
you have to run two wires to work that thing...one to the ecu A17 (pink and ...)
and the other is 12volts (yellow with black strip)
#3 is knock sensor...run one wire to you ecu D3
#1 is the actuator for the secondary's in the gsr intake manifold
#2 is where the vacuum lines go for the secondary's on the manifold\
#3 is the oil pressure sendor ( not positive on tech term, but i know green plug goes on there and its a bitch to get on and off
or is this strictly a b18c thing???
lastly, would a rechipped p28 ecu run this b18c???
or do i need to get a p72 ecu???
[Modified by degooser, 7:18 AM 2/23/2003]
the #1 pic is the vaccuum actuator for the secondary butterfly valve system, which is only on the GS-R engine. thay open at higher RPMs for better low-end/high end torque/power. #2 is the IAB that valves vacuum to the actuator, and #3 it the oil pressure sender/sensor. the knock sensor is higher up on the block than that.
unr8ed10
Jul 26, 2010 01:30 AM
949
Feb 4, 2007 04:35 PM
Pioneer162
Jun 3, 2005 01:51 PM
STN_Pat
Jun 16, 2003 12:53 PM
