STS Type R Sway bar question
The rule states
17.7. ANTI-SWAY BARS
Any anti-sway bar is permitted. Bushing material, method of attachment, and locating points are unrestricted. This does not authorize removal of a welded-on part of a subframe toa ccommodate the installation. Components such as anti-roll bars and strut housings which serve dual purposes by also functioning as suspension locators may not be modified in ways which change the suspension geometry or steering geometry
So removal of those nuts takes you out of STS???? Yes or no?? any tech inspectors know?
[Modified by JSR3STS, 3:48 AM 2/23/2003]
I don't think they would care because the civics that didn't come with a sway bar wouldn't have the nuts to remove. They couldn't let one of those run one and the teg not since they have virtually the same suspension.
silverCRXTC
46
Feb 18, 2004 08:24 PM
JSR3STS
Feb 23, 2003 03:35 PM
