vtec working off and on
Old Feb 22, 2003 | 10:58 AM
goforbroke's Avatar
MEAT PATTY
Default vtec working off and on
I've been noticing this now for about 2 weeks now. It pulls hard in first and second gear but then after 3 gear it doesn't seem to be working, or it will engage and then disengage. It seems like it will work when it wants to. I have no cel either. its on first gen b16a. I have the right amount of oil also. I not sure of what all to check like vtec soleniod voltage. I need help fellows any advice would be helpful.
Old Feb 22, 2003 | 11:57 AM
sslude's Avatar
Default Re: vtec working off and on (goforbroke)
chekc vtec solenoid, oil, make sure you warm up your car, check all hoses, ect
Old Feb 22, 2003 | 11:58 AM
Kamin's Avatar
do you hear it engage? because vtec dosent make as much power as you go up in gears.
but anyway, here is my troubleshooting guide, it will cover almost everything.
https://honda-tech.com/zerothread?id=164863
Old Feb 22, 2003 | 01:13 PM
goforbroke's Avatar
MEAT PATTY
Default Re: vtec working off and on (Kamin)
Everything else checks out except I need to check my vtec solenoid next, hopefully that is the problem.
Old Feb 23, 2003 | 05:49 PM
Jason.H.'s Avatar
idk if it would matter much but maybe ur vtec solinoid isnt grounded properly????
good luck
Old Feb 23, 2003 | 07:08 PM
tinkerbell's Avatar
Default Re: vtec working off and on (hondagod)
good luck
nope, the VTEC solenoid grounds itself by being attached to the head. it would have to fall off to not ground properly
it sounds like it might be oil pressure related...
is your oil level OK?
t..
[Modified by tinkerbell, 2:09 PM 2/24/2003]
Old Feb 24, 2003 | 03:26 AM
AussieK24's Avatar
Default Re: vtec working off and on (tinkerbell)
I've just finished baffling my sump as mine was doing this exact same thing. You'll probably find that your running to light an oil too.....
Old Feb 24, 2003 | 07:03 AM
goforbroke's Avatar
MEAT PATTY
Default Re: vtec working off and on (b16a4me)
Yeah my oil level is ok. I might try different weight oil and see if that helps. I usually use castrol synethic 5-30, I guess I going to have to try 10-30 usaully though 10-30 isn't that much of a difference from 5-30. It can't be to heavy because its cold out and soon as I start my car I hear the valves tapping becasue the oil didn't shot up to that part of the engine yet, it always does that in the winter time, not in the summer though.
Old Feb 24, 2003 | 10:06 AM
silverCRXTC's Avatar
My Vtec seems to sucks also after second gear, first and second are hellishly loud and 3rd is kinda poopie (4th and 5th idk i got a ls tranny and well i dont speed that much so i imagine they suck too )
i saw it said something about the oilpan, and mine is a bit smashed up, idk i might try
Old Feb 24, 2003 | 11:35 AM
simplestyles's Avatar
you could check loose connections from the solenoid to the ecu. does it throw a code?
Old Feb 24, 2003 | 11:44 AM
Kataku2K3's Avatar
That's exactly what I would have said... Is your oil pan dented at all... My friend's B16A from HMO had this same problem... VTEC did the exact same thing... pick up tube was smashed in... Lack of oil let the thrust washers spin out and destroy the crank, block, and cracked all of the pistons.. Pretty shitty... But yea I would pull the oil pand and check everything... pump too... sorry if that was already mentioned but i just skimmed through the above posts.... Peace
Old Feb 24, 2003 | 04:47 PM
goforbroke's Avatar
MEAT PATTY
Default Re: vtec working off and on (Kataku2K3)
Ok, looks like I won't be doing anything for spring break except working on my car. I'm going to check the soleniod then the oil pump and then check my oil pan to see if I smashed it on anything, even though I don't recall me hitting anything but I"m still going to check.
em1_fox
Oct 11, 2007 06:27 PM
Fastwhip
Aug 2, 2007 03:58 PM
swappedcivic
Dec 14, 2004 08:30 AM
gsrhatch530
Mar 28, 2002 01:36 PM
Teal95Coupe
Nov 25, 2001 06:29 PM
