please help , bad axle or............
Old Feb 22, 2003 | 08:38 AM
92hybridhhatch's Avatar
From: from Brooklyn NY U.S. Army recruiter in Holyoke, MA, USA
Default please help , bad axle or............
2 days ago I was driving and started hearing and feeling a nast thump thump thump coming from my frontt end , I feel it in the sterring wheel and I guess the whole car kinda vibrates pretty bad too , I did a search and heres what I understood from what i read , if the outer joints are bad then you hear clicking when your turning ( mine dont click when they are turning in either direction ) and your inner joints are bad you get a bad vibration while accelarating and braking , which is pretty much describes what i am getting , should i just replace my inner joints or do you guys think it could be something else????please help
Old Feb 22, 2003 | 09:40 AM
Chiovnidca's Avatar
Default Re: please help , bad axle or............ (92hybridhhatch)
Does it do it while braking, or on accel?
Old Feb 22, 2003 | 09:52 AM
TimoneX's Avatar
New User
Default Re: please help , bad axle or............ (Chiovnidca)
Be sure of what you're replacing. A warped brake rotor will do what you're describing as well, but the nature of the beast will change when you brake. A burned OEM Honda constant velocity joint will nearly always be accompanied by a torn CV boot.
Old Feb 22, 2003 | 11:46 AM
it does it while braking from high speeds and accelerating
Old Feb 22, 2003 | 03:59 PM
Chiovnidca's Avatar
A vibration braking is usually caused by warped rotors or drums. Sometimes a buildup of rust on the rear hubs can cause a problem on Civics. A vibration while accelerating is usually a bad inner CV joint.
SomeDude56
15
Dec 9, 2005 10:46 PM
mist sITR
Sep 25, 2003 11:02 PM
BlownREX
Jun 28, 2003 07:37 AM
all420
Feb 19, 2003 01:24 PM
Greyout
Jan 21, 2002 02:00 PM
