Is it possible to run a Component set and one Sub off a 2 channel?
Old Feb 22, 2003 | 08:21 AM
performula's Avatar
Default Is it possible to run a Component set and one Sub off a 2 channel?
Old Feb 22, 2003 | 10:47 AM
rcurley55's Avatar
New User
Default Re: Is it possible to run a Component set and one Sub off a 2 channel? (performula)
it's very possible...what you would need to do is purchase a tri-way passive crossover. Make sure that the sub can be wired to 4 ohm mono, and the comp sets are each 4 ohm. It;s not the best way to do it, but it would work. I certainly wouldn't recommend it though.
Old Feb 22, 2003 | 04:36 PM
Audio28's Avatar
Default Re: Is it possible to run a Component set and one Sub off a 2 channel? (rcurley55)
yeah i wouldn't do it either. the power and clarity is gonna be there. your music is gonna sound like crap. just go out and purchase another amp and do it right!!
Old Feb 22, 2003 | 05:55 PM
audioroach's Avatar
Default Re: Is it possible to run a Component set and one Sub off a 2 channel? (Audio28)
Ahhh....yes it can be done and sound great ( lets face it im real old
school....ie rockford peanut days),contrary to what was posted above.
You can actually run a whole system off of it with the proper xover network
its really sweet when its done right,but as stated above it,dont expect to have
club level power output. I'll see if I can find a pic for you of what I have sitting
in a closet....you would freak out.
Old Feb 22, 2003 | 06:18 PM
audioroach's Avatar
Default Re: Is it possible to run a Component set and one Sub off a 2 channel? (audioroach)
If you want the real deal go here:
Look at system 5...the model with the adjustable output for fronts/rear and fixed sub...use the one with the most amp capacity.
Now go play nice.
[Modified by audioroach, 9:22 PM 2/22/2003]
Spicoli v 3.0
Audio / Security / Video
Dec 16, 2005 06:31 AM
Pworld
May 28, 2004 11:58 PM
EF-Pimp
22
Nov 26, 2003 08:10 PM
FatJoe
10
Sep 3, 2003 04:13 PM
o_O
Jan 24, 2003 10:39 AM
