4-1 or 4-2-1?
Old Feb 21, 2003 | 08:16 PM
civic596's Avatar
Default 4-1 or 4-2-1?
I know I posted this in the other forum, but maybe I will get some help in this forum..thanks
We have one 4-1 header on our 99 Si, and one 4-2-1 on the other 99 Si. We tried doing a 3rd gear pull tonight. (Friday) First we both had to be in 3rd to make it fair..so from 75-80 mph we looked at eachother and nodded. Shifting into 3rd and letting out on the clutch...I hear him ready and we punch it at the same time. First we were even, then after shifting into 4th I started to pull. (I have the 4-1) I pulled pretty much through 4th never getting more than a few 5 feet from him. ( his front end came to my side door) As we shifted into 5th he started pulling pretty well. Enough to catch up and pass somewhat. And we gave up after hitting 120 mph.
Which one is better? He does have a street/strip clutch but does that have anything to do with it? I am installing one on mine wednsday.
Old Feb 21, 2003 | 08:48 PM
qtiger's Avatar
Default Re: 4-1 or 4-2-1? (civic596)
Results depend far more on the design of the header rather than 4-1 or 4-2-1. There are so many ways to set up a 4-2-1 that virtually any effect is possible.
Old Feb 22, 2003 | 09:34 AM
TimoneX's Avatar
New User
Default Re: 4-1 or 4-2-1? (qtiger)
That's hardly a controlled experiment. I've been with a 4-2-1 Comptech header for nearly 2 years and couldn't be happier.
Old Feb 22, 2003 | 11:28 AM
Audio28's Avatar
Default Re: 4-1 or 4-2-1? (TimoneX)
what kind of 4-2-1 and 4-1 was it?
Old Feb 22, 2003 | 11:50 AM
sslude's Avatar
Default Re: 4-1 or 4-2-1? (Audio28)
wtih a 4-1 header you'll get more high-end power and wtih a 4-2-1 header you'll get more mid-range power.
Old Feb 22, 2003 | 01:54 PM
civic596's Avatar
They are both DC Sports.
Old Feb 22, 2003 | 01:55 PM
civic596's Avatar
Default Re: 4-1 or 4-2-1? (sslude)
Would that be why I pulled then he did? Or no because he started to pull in 5th. I don't know but it is fun to go that fast.
Old Feb 22, 2003 | 02:34 PM
altoid's Avatar
shorter primaries are good for top end...
Old Feb 22, 2003 | 04:51 PM
kb58's Avatar
Banned
Default Re: 4-1 or 4-2-1? (Esquared4)
True, which would seem to argue *against* 4-2-1s being for mid-range only. I was looking through a pretty good Honda tuning book... by SA Press I believe. I thought they liked the 4-1s better overall, even for mid-range. They presented dyno charts proving it. Guess I need to buy the book...
[Modified by kb58, 1:53 AM 2/23/2003]
Old Feb 22, 2003 | 06:39 PM
redhnda's Avatar
New User
After install this DC header in your. Did you notice a different in power .
Old Feb 22, 2003 | 09:50 PM
HyBriDcxR's Avatar
Default Re: 4-1 or 4-2-1? (redhonda)
I noticed a different after i installed my 4-2-1 airmass compblu header.
Old Feb 23, 2003 | 07:55 PM
civic596's Avatar
Default Re: 4-1 or 4-2-1? (HyBriDcxR)
Yes, I noticed it in his car. With the 4-2-1. I am not too sure the up in horsepower in mine because I still have the stock clutch in it. After Wednsday I will know for sure. I will have a better clutch and better times.
Old Feb 23, 2003 | 10:57 PM
Volcom's Avatar
Clutches don't give you any HP, unless they are worn and are slipping. Your friend doesn't have an advantage over you just because of his clutch. How many miles are on your clutch? I went 137K on my stock clutch.
beastman@
Oct 23, 2007 12:02 AM
blackccoupe
Apr 26, 2007 10:39 AM
sshaikh01
Sep 27, 2003 02:52 PM
OneFastGsr
Aug 15, 2003 09:51 AM
civic596
Feb 22, 2003 07:04 PM
