VTEC on carbs
Old Feb 21, 2003 | 04:42 PM
abban's Avatar
Default VTEC on carbs
wondering how vtec runs on carbs not in computer system?
heres da hints..
Old Feb 21, 2003 | 05:06 PM
dkim48's Avatar
Default Re: VTEC on carbs (abban)
Why carbs?? EFI is much better, IMO. How much power you making with those? Any dyno pics. Thanks
Old Feb 21, 2003 | 05:15 PM
(teh)H2OUUP2's Avatar
Default Re: VTEC on carbs (dkim48)
What kind of vacuum advance distributor did he use?
Old Feb 21, 2003 | 06:01 PM
90accord1's Avatar
either im retarded or i cant see? its either connected to the distributor and in that case im assuming vtec is always on? or its ran to an rpm activated switch? distributor could possibly be a modified cardbed d series?
[Modified by 90accord1, 9:02 PM 2/21/2003]
Old Feb 21, 2003 | 08:50 PM
qtiger's Avatar
Default Re: VTEC on carbs (90accord1)
I really don't see the point in going from EFI to carb.
Old Feb 23, 2003 | 07:25 PM
90accord1's Avatar
Default Re: VTEC on carbs (qtiger)
not a lot of people seem to see the point of going carb.nor do they understand..no reason to knock on it though..
Old Feb 23, 2003 | 08:15 PM
TREVER's Avatar
Crbs are a very effective way of gaing poor mans power, Due to the drop in prices and increased options efi out performs imo. There are execptions ask Bisi. I own a set of mikuni carbs but chose efi.
Old Feb 23, 2003 | 08:25 PM
One 38's Avatar
Default Re: VTEC on carbs (TREVER)
very nice man...could you send me some info??
Old Feb 23, 2003 | 08:38 PM
TREVER's Avatar
Default Re: VTEC on carbs (ItsAllAboutTheZC)
what do you want to know about? basically my ZC is carbed my b20vtec is fi. Each set up had a different budget.
Old Feb 24, 2003 | 08:59 AM
Wazup's Avatar
can someone explain what he's showing us?
Old Feb 24, 2003 | 11:49 AM
eg6madness's Avatar
Default Re: VTEC on carbs (Wazup)
yeah i would alos like an explaination on how it is done.
Carbs make alot of power and work almost as good and ITBs ( notice i said almost). I dont understand how they work on VTEC but i have seen them work on out vehicles and work really well.
Only one prob, Carbs dump alot of fuel so you will need to go to the gas station more often
Old Feb 28, 2003 | 01:54 PM
eg6madness's Avatar
Default Re: VTEC on carbs (eg6madness)
How d o ya do the VTEC to Carb thing ?????????????????????????????
Old Feb 28, 2003 | 02:07 PM
Wazup's Avatar
u can tune carbs to be more fuel efficient.. bisimoto tuned his and he got 27 mpg back in in the day. I always think its funny when people compare carbs to ITB's, it has been proven that with the proper tuning, carbs can make the same amount and sometimes even more power than ITB's... also, ive heard the fuel atomization is much better with carbs, and the best part, they cost a lot less
Old Mar 1, 2003 | 10:12 PM
eg6madness's Avatar
yeah but does anyone know how to make VTEC work it Carbs ?
Old Mar 1, 2003 | 10:47 PM
Westrock2000's Avatar
I dont think this is a project anybody should take on, unless they have a race only car. ITB's might be ok for daily driver, but it better be a 9k+ RPM daily driver.
FWIW, NOPI sells weber carbs. Look under integra and either intake or engine component.
Old Mar 1, 2003 | 10:49 PM
MikeSarr_GSR's Avatar
I'll bet those motors when sized with the proper carbs and tuned properly are torquey as heck...
Old Mar 3, 2003 | 06:09 AM
fathergoose's Avatar
Default Re: VTEC on carbs (MikeSarr_GSR)
Dope ****!
Old Mar 3, 2003 | 09:22 AM
misledyouth's Avatar
New User
Default Re: VTEC on carbs (fathergoose)
fuel atomization is better with carbs. this would be a projec tthat would be much more easilly taken on if you had experience in past with carbs. Even just snowmobiles and ****.
jesse
Old Mar 3, 2003 | 09:55 AM
turbodsmpower's Avatar
Default Re: VTEC on carbs (misledyouth)
why does everyone ask how would vtec work get an rpm activated switch doesnt need a computer for this and hook it up. that is. I want to know where they got the carbs to fit on the bseries head they never made any carberated bseries is a custom fabed intake?
Old Mar 3, 2003 | 11:10 AM
eg6madness's Avatar
Default Re: VTEC on carbs (turbodsmpower)
where can i get a VTEC activation switch ? or how can i make one ?
Old Mar 3, 2003 | 02:09 PM
New User
a place called paeco sells a kit for the b16 i have a catalog here with me. they come with webers
jesse
Old Mar 3, 2003 | 02:44 PM
Wazup's Avatar
u can find carbs on ebay or wither fabricate ur own manifold or buy one from TWM. also, although an activation switch would work, i heard that over time, they can burn out ur vtec solenoid. also, ive heard one reason that carbs may not be good with vtec is that the carbs cannot compensate for the vtec changeover.
Old Mar 3, 2003 | 02:55 PM
Hondaaccordvtec's Avatar
CLEAN those plug wires man!!
Old Mar 3, 2003 | 04:32 PM
Default Re: VTEC on carbs (Hondaaccordvtec)
how does the rpm activator switch(which by the way msd carries them they are like 100.00 bucks and you can change the pills to get vtec to kick in whereeveryou want) ware out the vtec selonoid it does same thing that the computer does your just altering at what point it engages just like a switch.
Old Mar 3, 2003 | 04:52 PM
Tbone's Avatar
You guys are all forgetting the fact that you need to add a bunch of fuel when vtec activates. So there goes just a rpm switch idea. I beleive the vacume advance idea is more along the right direction, with the rpm switch.
JAYDmManny1331
Sep 18, 2009 08:01 AM
dapump2003
Jul 17, 2007 08:47 PM
Audi A4
Sep 15, 2003 09:26 AM
