Want type of shift lights do you use?
Old Feb 21, 2003 | 04:05 PM
GreenBean's Avatar
Default Want type of shift lights do you use?
I am looking to install a shift light of some kind in my hatch.
Questions are 1-It is stripped and I want something discrete.
2-I do not want a large tach in the vehicle.
3-Does anybody have the Axas shift indicator?
Anyway, what are you using and does it work for you?
Thanks for the info.
Old Feb 21, 2003 | 04:19 PM
IWearMyKswiss's Avatar
New User
Default Re: Want type of shift lights do you use? (GreenBean)
im not running just a shift light,..im running a pivot tach with pivot shift light,...as for you wanting it to be discreet,..i remember someone posting a picture of thier shiftlight behind the center air vent,..it was a sweet spot to put a shift light,..you really can only see it when its time to shift
Old Feb 21, 2003 | 04:22 PM
MrJasey's Avatar
i have a shift light some guy makes and sells online for like 30or40 bucks...he sells different colors and they are programmable to any RPM (in 100 RPM intervals) and you dont need a pill for different ranges like lots of autometer ones do
i just have the small tube with the light in it and use my stock tach, it works very well...i use it all the time, especially merging on highway
Old Feb 21, 2003 | 04:23 PM
redline201's Avatar
Default Re: Want type of shift lights do you use? (WiDeBoDyEK)
pivot makes a really small shift light that you can plug into your cigarette lighter
i hard wired it (simple)
it works pretty damn good and its really small
pretty clean looking if ya ask me
email me for pics
Old Feb 21, 2003 | 04:29 PM
hatchback's Avatar
pivot!
I think it will be perfect for your ride.
No wiring involved, just hook it up to your cigarette lighter and its done. I think it is also very accurate, and you are probably going to ask if it is bright or not. IMO: it is bright and it attracts my attention.
[edit: a better description]
[Modified by hatchback, 5:30 PM 2/21/2003]
Old Feb 21, 2003 | 04:39 PM
lazy bum shaughn's Avatar
Default Re: Want type of shift lights do you use? (hatchback)
Where does it detect your RPM? From the distributor?
Old Feb 21, 2003 | 05:31 PM
degooser's Avatar
how much for that pivot shift light...i like it..!!!!
Old Feb 21, 2003 | 06:07 PM
tominos's Avatar
one of my friends is running the axas shift indicator on his rsx, and it's pretty nice. i'm running the big monster tach w/ shift light.
Old Feb 21, 2003 | 06:12 PM
slomofo's Avatar
GDD Member
I'm using this really cool green arrow shift light that helps my gas mileage out.
Old Feb 22, 2003 | 12:40 AM
josups's Avatar
Default Re: Want type of shift lights do you use? (slomofo)
where can i get one of these pivot lights???
Old Feb 22, 2003 | 04:27 AM
00-ITR-373's Avatar
Default Re: Want type of shift lights do you use? (josups)
http://www.jdmspecperf.com/
Click on new shipments and scroll down, it's in there.
Old Feb 22, 2003 | 04:35 AM
silverEH2's Avatar
thats the dope cx/dx ish
mine doesnt work though with my swap
Old Feb 22, 2003 | 07:44 AM
Nothing.Special's Avatar
anyone else have any reviews of the pivot shift light?
Old Feb 22, 2003 | 08:10 AM
josups's Avatar
Default Re: Want type of shift lights do you use? (Nothing.Special)
up
Old Feb 22, 2003 | 05:21 PM
josups's Avatar
up
Old Feb 22, 2003 | 05:25 PM
Eee Pee's Avatar
I was given a shift light when I was born....my hearing.
And the feeling that the car isn't accelerating anymore.
Old Feb 22, 2003 | 06:23 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: Want type of shift lights do you use? (Eee Pee)
OEM.
Old Feb 22, 2003 | 06:28 PM
steve_s's Avatar
Default Re: Want type of shift lights do you use? (SpoonSportsEH2)
I think shiftlights are useless, or atleast for me because I shift at different points with each gear. When going from 1st to 2nd ill shift around 2500-3000 and anything on up ill shift at 4000-5000.
Old Feb 22, 2003 | 07:05 PM
tominos's Avatar
Default Re: Want type of shift lights do you use? (steve_s)
even when you're racing?
the main purpose of a shift light is to let you know when to shift w/o looking at tach.
Old Feb 22, 2003 | 07:15 PM
del_sol's Avatar
Default Re: Want type of shift lights do you use? (tominos)
If you need to look at a light to know when to shift- you shouldn't be driving an import. I don't know about you people out there, but I've learned my motor, I can feel/hear it and know exactly when to shift throughout the diff. gears. Im not saying im some crazy *** NIRA champ-but shifting chouldnt require a light.
Old Feb 22, 2003 | 07:21 PM
gsrvx's Avatar
New User
Default Re: Want type of shift lights do you use? (JDMDELSOL)
my check engine light
Old Feb 22, 2003 | 07:33 PM
hatchback's Avatar
FYI: I think he was referring to a "racing" shift light. One that lets you know when to shift right before your redline.
Old Feb 22, 2003 | 07:37 PM
redline201's Avatar
the best part of the pivot light is you can easily hard wire it
and its small and clean looking
lilxvtecxpwr's Avatar
hondata shift light
Old Feb 22, 2003 | 07:44 PM
5thgen's Avatar
Default Re: Want type of shift lights do you use? (lilxvtecxpwr)
its not a shift light....(vtec led)....lets me know when i kinda get close to redline
but all i would need is an msd rpm switch....soooo
and shift lights would help me out...i've just switched back from a dx tranny to an ex tranny....the end of a gear comes a lot quicker...i've hit the limiter, not a whole lot, but more than once.
http://greddyd16.tripod.com/sitebuil.../shiftlite.wmv
[Modified by 5thgen, 4:51 AM 2/23/2003]
