Hi im new and i have a few questions! :)
Old Feb 21, 2003 | 03:37 PM
Luka's Avatar
Default Hi im new and i have a few questions! :)
Hi ok so yeah i have a 91 civic si hatch (moonroof) anyways anybody ever have probs with it leaking? like were talking drenched as in couple inches on the floor if u park outside on avery rainy night yeah it leaks in on the side like at the bottom of the dash on either sides (driver/passenger). anybody ever have that problem? if so how did u resolve it? thanks in advance
Old Feb 21, 2003 | 03:48 PM
dRuNk-dRiVer's Avatar
Default Re: Hi im new and i have a few questions! :) (Luka)
~89crxsi~ my moonroof leaks... passenger door, and driver door leaks... not to mention i think my trunk leaks 2 ... ooh and no i didnt get it fixed. just got a car cover on rainy dayz
Old Feb 21, 2003 | 03:52 PM
pdiddyparsons's Avatar
buy a rain coat and a boat!! good luck
Old Feb 21, 2003 | 03:53 PM
Luka's Avatar
LMAO haha ok so it could be my doors.. cuz i cleaned out my drains but then again the drains might be cracked so ima rip out the interior and take a peep other ethen that my trunk doesnt leek and yeah *cryes*
Old Feb 21, 2003 | 03:54 PM
Malgerus's Avatar
Try getting your weatherstripping replaced. It is over a decade old, ya know. Also, as for the hatch area, it could be your tailight seals leaking.
Old Feb 21, 2003 | 03:58 PM
Luka's Avatar
ok so the door weather stripping? and if not that do you think its worth it takeing the interior appart to check if the tubeing maybe got cracked or it moved or something wrather?
Old Feb 21, 2003 | 07:42 PM
Luka's Avatar
Old Feb 21, 2003 | 08:08 PM
SEA Hag's Avatar
For the hatch leaks, check the seams around the bolts where the hinges are for leakage. Use some sort of sealant if you see anything questionable
Old Feb 21, 2003 | 08:14 PM
cutt's Avatar
for the moonroof leak there are drains for it that run out your wheel wells .if they have been plugged the inside of the roof where the glass slides in fills up to fix this use an air hose to clear the drain lines BECAREFUL you don't blow the seals out .
Old Feb 22, 2003 | 06:46 PM
Luka's Avatar
Default Re: Hi im new and i have a few questions! :) (cutt)
shibby ok uhmm yeah they run down ive used the air hose thing in the past didnt reaally help much could the lines be broken or perhalps the seals gone?
Old Feb 22, 2003 | 11:10 PM
Shawn C's Avatar
In The Garage
um, like, yeah, um, like i hope you don't talk like that. anyways, id go to honda and buy new seals for them all. the best $75 you ever spent. after it doesn't leak anymore, replace your carpet and clean everything good.
Old Feb 23, 2003 | 12:20 PM
slopok7's Avatar
I had the same problem with my 90 dx but it didnt have a sunroof.
I just took out the carpeting and found out that the body was a little rusty
I just bondoed the rusty spots and I never had another leaky problem.
Old Feb 23, 2003 | 02:34 PM
Luka's Avatar
Default Re: Hi im new and i have a few questions! :) (22lbGS-R)
heh i dont talk like that so i just go to honda and do the seals have like a specific name i dun feel like gettin fuked around at honda ty
LJPortilla
Classic Hondas
Jun 13, 2019 02:18 PM
silversurfer87
Honda Civic (2006 - 2015)
Oct 26, 2010 06:02 PM
hotwater
26
Aug 8, 2008 03:44 PM
tehondafrk
13
Feb 26, 2008 10:59 PM
nc-rsx-s
10
Jul 17, 2002 01:24 PM
