filling mounts
Old Feb 21, 2003 | 12:16 PM
Old Skool's Avatar
Default filling mounts
what kind of materal is really good for filling mounts, and is it a safe thing to do?
Old Feb 21, 2003 | 12:33 PM
B18EG6's Avatar
Default Re: filling mounts (Old Skool)
3m window weld. I filled the drivers side mount. Most people say they wont do it ause its too messy but in reality its not that bad. Just put tape on one side so it doesnt goo out, fill it from the other side...and sand it off if you want
Old Feb 21, 2003 | 12:36 PM
4g4me's Avatar
when i was young, i filled the motor mounts of my race car, a 4th gen hatch, with a mixture of fiberglass resin, unstrung fiberglass matt, and play sand.
I experienced no wheel hop, there was no movement, and I could catch 3rd with a stock clutch, where as i couldnt catch second before, so there is definitely positive momentum transfer, which was being lost with the rubber mounts.
Old Feb 21, 2003 | 01:18 PM
Old Skool's Avatar
Default Re: filling mounts (4g4me)
hmm...sounds like it makes quite a diff. when i got my new moter the phucker wiggled all over the place when i would gas it and energy only makes one mount insert for my car...thats not enough cuz i gotta do the trans mount as well. thx
Old Feb 21, 2003 | 02:33 PM
SamC's Avatar
where do you guys buy the materials?
Old Feb 21, 2003 | 03:18 PM
Blaze45's Avatar
Brrraaaap!
Default Re: filling mounts (SamC)
yeah where did you get all those things you put in your mixture?
Blaze
Old Feb 22, 2003 | 05:27 AM
Blaze45's Avatar
Brrraaaap!
Default Re: filling mounts (Blaze45)
anyone?
Old Feb 22, 2003 | 08:46 AM
TimoneX's Avatar
New User
I simply used black RTV silicon. Taped one side and used a caulking gun to fill that sucka up. My thinking was that the stock mounts are hollow and rather flimsy, so filling it with soft material would be a good comprimise between lotsa vibration and allowing the engine to torque sideways. I did all of them this way BTW. Initial results were promising, there's a definite increase in vibration, but it's not great and the clutch was brand new(Action Kevlar), so it's hard to tell what difference came from what, but I was blown away at how rapidly the car responded to input after that.
Old Feb 22, 2003 | 11:04 AM
Old Skool's Avatar
Default Re: filling mounts (TimoneX)
how much is that stuff and where did you get it? does it deteriorate at all? and how stiff is it? thx
Old Feb 22, 2003 | 11:28 AM
TimoneX's Avatar
New User
It's about $5 for a tube, and I got it at the local hardware store. It's moisture proof, I don't suppose it'll last forever with the heating and cooling effect, but I don't anticipate problems for years. Not sure how to answer your last Q. It's much stiffer than stock...but less stiff than urethane mount inserts. Cheap too.
Old Feb 22, 2003 | 12:17 PM
Old Skool's Avatar
fo sho, thanx mang!
Kaspk
17
Jan 19, 2008 06:54 PM
bluesihatch
Suspension & Brakes
May 1, 2007 01:43 PM
george34
21
Jan 22, 2006 07:30 PM
ragejed
May 18, 2002 06:56 PM
