Higher oil press. good for high comp? HAMP question also
Old Feb 21, 2003 | 11:08 AM
UltRaH22's Avatar
Default Higher oil press. good for high comp? HAMP question also
i just got my shipment of the new smaller sized HAMP filters... i gotta say they are MUCH smaller when next to a reg one. i heard the small ones raise the oil pressure like 5 psi??? anyone else heard this? i also need to know if this is better or worse for my High compression/ NOS motor... thanks
Old Feb 21, 2003 | 11:42 AM
CHEETAH's Avatar
Default Re: Higher oil press. good for high comp? HAMP question also (Option2 eg6)
i saw a 4psi difference in my race car from small hamp race to stock honda filter.
More oil pressure is better regardless of induction.
greg
Old Feb 22, 2003 | 10:51 AM
UltRaH22's Avatar
bump
Old Feb 22, 2003 | 11:06 AM
dfoxengr's Avatar
i use a stock HONDA rsx filter on my bseries its supposed to raise like 3psi or something..but yes better PSI is better..
Old Feb 22, 2003 | 02:41 PM
altoid's Avatar
Default Re: Higher oil press. good for high comp? HAMP question also (hybridvteceg)
you can put a washer around the pump opening or something like that (i've got the how to if you want it) and it raises pressure no matter what filter you run
Old Feb 22, 2003 | 07:17 PM
Patch's Avatar
Default Re: Higher oil press. good for high comp? HAMP question also (Esquared4)
Isn't that also a good way to blow up your oil pump?
Old Feb 22, 2003 | 08:26 PM
sgT's Avatar
sgT
Default Re: Higher oil press. good for high comp? HAMP question also (CRX PAT)
no because you are adjusting the bypasss valve on the pump.
i would raise pressure from the pump and stick with the regular filter.
frankie11
12
Jul 1, 2007 12:18 PM
lude98SH
Jun 21, 2007 07:09 AM
igo4bmx
Nov 19, 2003 06:25 PM
JPowers
Feb 17, 2003 08:16 PM
ithrowpoop
Jan 27, 2003 08:12 PM
