larger oil filters
larger oil filters
anyone use larger than stock oil filters?
with the new OEM filters raising oil pressure and degrading quality, what are some good oversized oil filters?
Re: larger oil filters (b18bturbo)
im using a wix filter right now! seems good, good pressure, no leaks, and supposed to be a good filter....i think or at least from what i have heard
OG triple OG
Re: larger oil filters (Ricey McRicerton)
anybody with oil pressure guages notice a difference wit the s2k filter , i was gonna use it ,but ive herd even those have cause higher pressures
where can you get the wix filters?
Re: larger oil filters (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">anybody with oil pressure guages notice a difference wit the s2k filter , i was gonna use it ,but ive herd even those have cause higher pressures
where can you get the wix filters?</TD></TR></TABLE>
When I was using the smaller filter, it upped my oil pressure enough that I was leaking oil past the turbo seals. Now I'm not having any trouble with that.
NAPA... NAPA part # 1334 Same as WIX part # except for first #. Same filter, i use them all the time... make sure you get teh 1334 which is the Gold instead of the 21334 which is the cheaper Silver line.
-Brian W.
-Brian W.
you can find out here. http://www.wixfilters.com/wheretobuy/index.asp
Si Erik
26
09-08-2003 06:02 AM
