advanced the distributor..bad? good?
Old Feb 20, 2003 | 11:22 PM
ILOVEGIRLS's Avatar
Default advanced the distributor..bad? good?
does advancing the timing on your distributor harm your engine? btw, which way is advancing?
Old Feb 21, 2003 | 05:07 AM
Eva01's Avatar
Default Re: advanced the distributor..bad? good? (ILOVEGIRLS)
Read up on advancing your timing here . HTH
Old Feb 21, 2003 | 11:36 PM
ILOVEGIRLS's Avatar
Default Re: advanced the distributor..bad? good? (Eva01)
that link only brought me to another site
Old Feb 22, 2003 | 12:28 AM
ill phil's Avatar
With good info, join and read up!
Advancing your dist. a few degrees will help and won't hurt as long as you don't overdue it and cause detonation. You'll need a timing light and what not to correctly advance your timing.
Old Feb 22, 2003 | 04:59 PM
ILOVEGIRLS's Avatar
Default Re: advanced the distributor..bad? good? (ill phil)
thanks! I cant leave honda tech..
sikek1
Apr 28, 2008 05:49 AM
allnaturalb16
21
Aug 14, 2007 08:57 PM
miksew
Jun 7, 2006 08:03 AM
johnbrooke86
Aug 23, 2004 04:49 PM
AcE
Jun 29, 2001 12:48 PM
