how to polish valve cover
Old Feb 20, 2003 | 10:30 PM
NightHawkC5's Avatar
Default how to polish valve cover
how do you guys make your valve covers like their crhomed out, nice and polished, and shiney, without buying one obviously?
Old Feb 20, 2003 | 10:36 PM
GTlvr82's Avatar
Default Re: how to polish valve cover (NightHawkC5)
Well, from my experience I just bought 300 grit and sanded using aluminum polish and worked my way up to 800 grit and then used high heat clear coat so it didn't tarnish or get **** on it...my .02
Old Feb 21, 2003 | 05:47 AM
cleanEG's Avatar
Default Re: how to polish valve cover (GTlvr82)
Lots and lots of mother's aluminum polish after removing the wrinkle paint and sanding as mentioned before. I also took 1000 grit and wet sanded it before polishing. Thats it!
Old Feb 21, 2003 | 09:57 AM
t-blizzard's Avatar
cut it, then buff it
Old Feb 21, 2003 | 10:19 AM
lowcivex's Avatar
A 3m pad would work and then finish it up by hand sanding then a clearcoat.
Old Feb 21, 2003 | 11:16 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: how to polish valve cover (lowcivex)
im actually going in the garage to do that now, ill send a pic when im done... i did up to 400 grit already, 600-800-1000-1500-2000 (if i can find it) then mothers polish
Old Feb 21, 2003 | 03:20 PM
Default Re: how to polish valve cover (SIXTYdashONE)
so i should do 1500 grit then 1000 then 800 then 600 then down to 400 then use mothers aluminum polish? also what should i use to sand it by hand or what? and how much should i sand it at each grit. also i sandblasted it so i dunno. someone help me out
[Modified by NightHawkC5, 12:25 AM 2/22/2003]
Old Feb 21, 2003 | 03:39 PM
JDubya's Avatar
wouldn't u wanna start w/the 400 then work your way up to the finer stuff, then polish?
Old Feb 21, 2003 | 08:45 PM
cleanEG's Avatar
Default Re: how to polish valve cover (ALL MOTOR LS)
Yes! work your way from the lower numbered sandpaper to the finest sandpaper you can get...then polish with mothers... and polish...and polish
arrocha87
Mar 19, 2009 08:49 PM
pjr710
Paint and Body
Aug 10, 2007 07:24 PM
94c1v1cex
Paint and Body
Jun 5, 2007 06:56 AM
greddyturboGSR
Apr 7, 2003 07:10 AM
pg_thao
Mar 11, 2002 05:55 PM
