Clutch or Slave Master Cylinder going bad?
Old Feb 20, 2003 | 08:58 PM
migs's Avatar
Default Clutch or Slave Master Cylinder going bad?
I just bled my clutch line to make sure it was clean of air. Also flushed the entire system as well.
I notice when I push my clutch pedal down, there is about 1" of play where nothing happens. It just feels "loose."
Can I just adjust the pedal height or is the little cylinder behind the clutch going out? I crawled under neath and saw a SMALL amount of oil trace in the push rod.
Thanks in advance
migs
Old Feb 20, 2003 | 09:10 PM
salbaje's Avatar
Default Re: Clutch or Slave Master Cylinder going bad? (Migs)
your master cylinder is going bad. dont buy rebuild kit coz it will go bad fast if you rebuild it. I was the guy at Brian's house when you put in the tranny for him in the 4 door.
Old Feb 20, 2003 | 09:11 PM
cheezthis's Avatar
If you see some fluid...then there's a good chance it's going out. I'm changing my friend's master and slave cylinders tomorrow night. I'll probably change mine this spring, I know they're starting to go.
Old Feb 20, 2003 | 09:19 PM
migs's Avatar
Default Re: Clutch or Slave Master Cylinder going bad? (cheezthis)
Thanks for the replies!
Old Feb 20, 2003 | 10:49 PM
Jowee's Avatar
Is it an inch of play when you just lay your foot on the pedal? My ACT street/stip disk and Xtreme pressure plate does that. Anthony's R does the same thing too. I wouldn't worry about it.
gooblinn258
Jan 18, 2014 05:02 PM
R81_DC2
Aug 14, 2009 08:54 PM
RDAYA0
Dec 14, 2006 05:31 PM
vlc92189
Nov 6, 2006 08:49 AM
Pandahatch
12
Aug 24, 2004 07:48 AM
