ls girdle install ?
Old Feb 20, 2003 | 08:25 PM
black-hatch's Avatar
Default ls girdle install ?
ok im putting a gsr girdle on my ls/vtec im just wonderin after i get it dowled and aligned will that mess up my bearing clearnces and fitment or will i be good with the stock main bearings still thx
Old Feb 21, 2003 | 08:17 AM
TimoneX's Avatar
New User
Default Re: ls girdle install ? (black-hatch)
I don't see why it would. Doesn't the girdle go over the main caps anyway? You may have oil pan clearance problems, but I wouldn't think you'd have bearing troubles.
Old Feb 21, 2003 | 10:17 AM
vbphreak's Avatar
Default Re: ls girdle install ? (TimoneX)
^ what he said.
your bearings will remain the same as it does go above the main caps. a main cap needs to be filed down to make the girdle fit properly. and make sure to get the gsr windage tray, cap bolts (6?), oil pickup and oil pan. check the link below.
https://honda-tech.com/zerothread?id=263598
preludeNApower
Aug 1, 2014 09:55 PM
abusedvtec
Jul 6, 2009 08:02 AM
wyroper
Mar 18, 2009 08:20 AM
CRXb18Turbo
Nov 10, 2005 02:31 PM
dumpeDc2
Oct 7, 2004 03:20 AM
