f22b1 I/H/E what next to make it run best and faster
Old Feb 20, 2003 | 07:19 PM
Rukusmasta2's Avatar
Default f22b1 I/H/E what next to make it run best and faster
waht do u think i would run1/4 as is and what should i be lookin at to get in the 14's
Old Feb 20, 2003 | 08:48 PM
1genCL's Avatar
Default Re: f22b1 I/H/E what next to make it run best and faster (Rukusmasta2)
try doing a search.
nx system, swap, or turbo.
i would take care of the ignition and fuel system before you go off doing anything crazy. there are plenty of mods left for you.
Old Feb 20, 2003 | 10:18 PM
Ryu's Avatar
Ryu
how much you wanna spend... 14s is feasible provided you spend enough dosh
Old Feb 20, 2003 | 10:37 PM
PUREVIL's Avatar
Default Re: f22b1 I/H/E what next to make it run best and faster (Ryu)
N2o, upgraded fuel system, swap, turbo..
what they said,, slicks maybe?
Old Feb 21, 2003 | 09:09 AM
CrazieLude's Avatar
cam, pullys, port, pollish, plugs & wires (dont do much)...do you have AT or MT? if you have a MT you can beef up all that. If you have an AT you can swap to MT.
Old Feb 21, 2003 | 01:57 PM
iam7head's Avatar
Default Re: f22b1 I/H/E what next to make it run best and faster (crazieaccord)
tires..N20
Old Feb 22, 2003 | 08:07 AM
twkdCD595's Avatar
Default Re: f22b1 I/H/E what next to make it run best and faster (iam7head)
juice or boost.
good tires is a must.
Old Feb 22, 2003 | 08:38 AM
Accord Man's Avatar
well with a f22 there isnt a whole lot that you can do. well there is but if i were you i would just save up $500 and slap some juice on. a 50 shot would be nice a 75 would push it. just dont use it under 3000 rpm. it will work on auto and manual since you havent specified which you have.
Old Feb 22, 2003 | 09:03 AM
93AccordCoupe's Avatar
Default Re: f22b1 I/H/E what next to make it run best and faster (Accord Man)
What times are you running right now with IHE on your F22? I hope with those mods you are currently in the very low 15's... so maybe even light wheels and drag compound tires would help you out.
With just an intake on my car, I'm running 15.8...
[Modified by 93AccordCoupe, 1:04 PM 2/22/2003]
Old Feb 22, 2003 | 09:09 AM
niedejb's Avatar
If I had a dime every time I heard that......
Old Feb 22, 2003 | 12:43 PM
Baltz's Avatar
Default Re: f22b1 I/H/E what next to make it run best and faster (niedejb)
LOL!!! and what are niedejb horsepower outputs again!!
I'm thinking about buying a a f22b and putting the engine in my car...
::hijacking::
neidejb do you think if I went the other way from turbo, which is higher compression pistons and all that good stuff that I would but anywhere close to 190 hp or so?
Old Feb 22, 2003 | 06:05 PM
niedejb's Avatar
Default Re: f22b1 I/H/E what next to make it run best and faster (4th gen accord)
I dont know. I couldnt get more than 143 out of her NA. That'd be a hell of a jump with just a compression change.
Maybe if you over bored and changed the compression.
Old Feb 22, 2003 | 07:59 PM
Accord Man's Avatar
this is why i just lurk b/c all your doing is highjacking this thread to up your post count. whatever. read what i put after that...."well there is"...i just dont want to have to explain myself. also you have a 4th gen. a f22 would be an upgrade from whatever pos engiene you got. and good luck finding one with low miles. it took me forever to just find one with 28,000. hope you feel special b/c you proabably cant tell the difference between a Rotary and a Precipitating engiene ya n00b so dont even run your mouth to me.
Old Feb 23, 2003 | 12:15 PM
twkdCD595's Avatar
your an idiot... you look like the only noobie fyi.
Old Feb 23, 2003 | 12:19 PM
97F22B2's Avatar
Default Re: f22b1 I/H/E what next to make it run best and faster (twkdCD595)
Im running the B2 and im going with a turbo and a built head, itsll all in what you have to time and money for but everyone knows that
Old Feb 23, 2003 | 12:35 PM
illi Adik's Avatar
If you are on a budget I would do a properly set up system of the juice.
Old Feb 23, 2003 | 04:15 PM
Accord Man's Avatar
no n00b i just dont really post that much
Old Feb 24, 2003 | 10:24 AM
twkdCD595's Avatar
good... I am sure it will save space for informed people to post.
Old Feb 24, 2003 | 01:27 PM
illi Adik's Avatar
Ha, be easy man.
Old Feb 26, 2003 | 07:13 AM
97F22B2's Avatar
Default Re: f22b1 I/H/E what next to make it run best and faster (Jackson4Door)
Jackson4dr i really dont like the "juice and my budget isnt that bad so a nice cam and turbo set up will do me just fine.
As for the thread i would next get a better cam for your Vtec motor and remap the ECU, but thats my two sense.
Old Feb 26, 2003 | 08:39 AM
Kwisatz Haderach's Avatar
Hello, for someone that calls himself Accord Man, you dont seem to know too much. The 4th gens came with F22a's, bud.
HidPerf
Feb 26, 2013 03:54 AM
danedoremus
Jul 28, 2010 08:29 AM
notorious30
Mar 23, 2004 05:21 AM
boostedinteg03
Jan 22, 2003 01:23 PM
dmotoguy
Jun 26, 2002 06:35 PM
