What size downpipe do you t3/60-1 owners use?
Old Feb 20, 2003 | 06:41 PM
LSiTurbo's Avatar
Default What size downpipe do you t3/60-1 owners use?
What size? 2.5" or 3" or transitioned? thanx...
Old Feb 20, 2003 | 06:58 PM
b18cTurbo's Avatar
Default Re: What size downpipe do you t3/60-1 owners use? (LSiTurbo)
3" would work well whit your 60-1
Old Feb 20, 2003 | 07:25 PM
DR. ON POINT's Avatar
Banned
Default Re: What size downpipe do you t3/60-1 owners use? (C5turbo)
Old Feb 21, 2003 | 12:36 AM
boostaholic's Avatar
Default Re: What size downpipe do you t3/60-1 owners use? (DR. ON POINT)
3"
Old Feb 21, 2003 | 04:27 AM
Farnsrocket's Avatar
Default Re: What size downpipe do you t3/60-1 owners use? (boostaholic)
Old Feb 21, 2003 | 04:54 AM
autoEXturbo's Avatar
3" would be good
Old Feb 21, 2003 | 05:04 AM
Adi Radoncic's Avatar
On Fire!
3" nothin less..
Adi
Old Feb 21, 2003 | 05:33 AM
boostin b16's Avatar
Default Re: What size downpipe do you t3/60-1 owners use? (newgsr)
I see everyone uses a 3in dp for there t3 60-1, but how? the 60-1 comes with a t3 turbine and it only has a 2.5in discharge. did you transition it? did you bend the piping in around the nolts on the flange? or did you get the 3in v-band conversion?
Old Feb 21, 2003 | 05:50 AM
Default Re: What size downpipe do you t3/60-1 owners use? (MY"little"T3)
I actually had to hammer the pipe in at the points where it made contact with the
DP bolts and I also used allen head bolts since they have smaller heads than the hex head bolts.
Old Feb 23, 2003 | 05:46 PM
LSiTurbo's Avatar
Default Re: What size downpipe do you t3/60-1 owners use? (Farnsrocket)
its decided im goin with 3" and V-Band set-up... thanx for your input all!!!
airusall
Mar 30, 2005 04:16 PM
Built B16A
Jun 30, 2004 07:58 AM
yusoslo
Feb 16, 2004 12:02 PM
