first post...motor rebuild??
whats up everyone....i have a 93 LS goin to start to rebuild the whole motor.
wanting to start at the bottom end. what are the best pistons and rods to get and how much should i bore it over
i dont want any turbo and i dont wanna do a ls vtec................just wanna build my motor it only has 70k on it i am lookin to spend around 3 grand on it.....i wanna get good stuff but it doesnt have to be the absolute best....what do u recomend in pistons and rods
i think he's just trying to do a normal rebuild, not one of those crazy 12.5:1 compression piston rebuilds
if that's the case, i would stick with oem parts. when i did my rebuild, i bought ITR pistons for an extra kick, so maybe you should concider getting ITR pistons, oem ls rods blah blah blah.
and if you learn anything about rebuilds on h-t, it's the HELMS.
[Modified by HKJ, 9:46 PM 2/23/2003]
b16 or R pistons not sure on price
crower 403 with valve train 900 plus install
Intake manifold 300
all depends on if u can do the work yourself, if u can u can do more becasue it will cost less.
Intake manifold 300
head.......skunk2 intake manifold, port and polished head, crower stage 2 cams with retainer/spring kit, aem cam gears, stock ls valves, would i be able to use my stock valve train with those stage 2 crower cams they are part #62403 on crower.com......
with the head done that way would i need to do my fuel.......what cam gears?
with those crowers you would definately need new valvesprings... stock retainers should be okay. if you are going to raise the redline for those cams ( i dont know what their powerband is) you might want to get them nitride coated... what are your power goals???? because getting high number on SOHC NA is a tough adventure (you definately can make some decent numbers w/ the right parts but it gets expensive just like an NA or FI setup).
queda
12
Nov 1, 2007 10:05 PM
