Pistons...
Old Aug 1, 2003 | 07:02 AM
BIntegra99's Avatar
Default Pistons...
If I put ITR pistions on a LS Block, Do I need to get machine work ?
Old Aug 1, 2003 | 07:40 AM
P1mpSlap's Avatar
Default Re: Pistons... (BIntegra99)
you have to mill the rods a little so it'll clear the pistons.
Old Aug 1, 2003 | 07:42 AM
haggar's Avatar
Well, I'm putting P30 (JDM B16) pistons in mine..
From what everyone tells me, you want new rings, so then you need to hone the block to allow the new rings to seat.
Which you are looking at tearing the block pretty much down to bare, so you can clean it right, after the honing.
Hoping more people will chime in with their responses. I'm pulling my motor next week to start installation of the new parts...
Old Aug 1, 2003 | 07:44 AM
haggar's Avatar
Default Re: Pistons... (haggar)
Oh, yeah.
I believe 1 mm off each side of the rods.
But, B16 pistons will go on without milling..
Old Aug 1, 2003 | 07:53 AM
BIntegra99's Avatar
Stock rods ?....and by mill...what do you mean ?
Old Aug 1, 2003 | 08:12 AM
haggar's Avatar
Search on this one, lots been posted.
The small end of the LS rod is too wide to fit the pistons. You have to mill the flat surfaces where the wrist-pin
Old Aug 1, 2003 | 08:25 AM
arw321's Avatar
Or you can have the pistons modified for the rods. I have .25 over CTR's on LS rods.
Adam
Old Aug 1, 2003 | 09:24 AM
BIntegra99's Avatar
Default Re: Pistons... (arw321)
If I was planning on doing an ls vtec. WOuld I be ok with just getting ITR pistons. Or should I get new rods too ? If I get the machine shop to hone my block. WOuld I be able to do the install of the pistons myself ?
Old Aug 1, 2003 | 09:28 AM
haggar's Avatar
Could get B16 (PR3)pistons, they are cheap, a little bit more compression that ITRs, less than CTRs..
Old Aug 1, 2003 | 09:36 AM
BIntegra99's Avatar
SHouold I keep stock rods. Or change ? PLanning on lsvtec
Old Aug 1, 2003 | 01:03 PM
l2Y4N's Avatar
you don't NEED rods, they'd help, just get some $30 arp rod bolts, you'll be good
skiracer8148
Jul 7, 2007 05:45 PM
SwappedTURBOegg
Mar 9, 2005 08:35 AM
ls_vtec_crx
Mar 11, 2004 09:57 PM
specie
Oct 13, 2003 11:34 PM
