why exactly do people get...?
Old Feb 20, 2003 | 04:51 PM
sslude's Avatar
Default why exactly do people get...?
why do peple get oil pressure gauges, and all thermostat, ect? can you guys list some stuff that people usually have on the guages and what they are used for. thanks
Old Feb 20, 2003 | 05:24 PM
kwil666's Avatar
Default Re: why exactly do people get...? (sslude)
i have a oil gauge so i know when my oil is getting low. i try to check it everytime i fill up but sometimes i forget. also when im driving hard the b18c1 is known for burning oil so i can go through oil quick.
keith
Old Feb 20, 2003 | 05:31 PM
integra6650's Avatar
Default Re: why exactly do people get...? (kwil666)
what do you mean do you want someone to tell you what each gauge is for(oil pressure, egt, boost, etc)
Old Feb 20, 2003 | 05:51 PM
slomofo's Avatar
GDD Member
I had a temp guage last year cuz my stock guage was broken and moved up and down almost as much as my tach.
keith
Hey, that's really cool, I wish I had something like that. I have something pretty close to that, but I think mine is better, it's called an oil dipstick, it also tells me if my oil is low.....hehe...jk.
Old Feb 22, 2003 | 08:33 AM
sslude's Avatar
Default Re: why exactly do people get...? (slomofo)
i meant like, and oil gauge shows this and that, and a fuel pressure guage shows this and that...ect
Old Feb 22, 2003 | 09:41 AM
Chiovnidca's Avatar
Which ones don't you understand?
Old Feb 22, 2003 | 09:58 AM
GZERO's Avatar
i can tell you a few, but just to be a good guy, but first, you need to know that stock gauges are not accurate at all.
EGT (Exhaust Gas Temperature) - Is used on turbo cars on the turbo manifold on cyl #3 (can't remember exactly) and it tells the owner if the combustion is good and it can tell you if your timming is too advance or retard as well to detect pinging or detonation
Oil Pressure - Engines need oil pressures, especially at high revs ( the rule of thumb was something around 10PSI for every 1K RPM) so if you are reving the engine high and you notice low pressures you know you need to stop and check.
Oil Temp - As you might now, oil also works as a coolant for the engine, it keeps temps down and lubricate the parts, after 300 F oil starts to evaporate (depending on oil that's it) It also can tell you if you need to run an oil cooler. Remember that the higher the temp the less viscosity the oil has.
Water Temp - Pretty much the same as oil temp, but is a lot more accurate than your stock one
Air/fuel ratio - Very important when tunning a car, but never get the goofy autometer air/fuel ratio, get a lambda meter, they might be costly but it'll worth every penny, when tunning a turbo car at WOT you look at something 12.5 and when tunning an N/A car you look at something around 13.5 at WOT, off course, but when you tunned for cruising you tunned for something around 14.7 which is stoick.
I know there are more, but these are the important ones, plus i'm tired of writting
Hope it helps
Old Feb 22, 2003 | 11:53 AM
sslude's Avatar
Default Re: why exactly do people get...? (GZERO)
Hope it helps
thanks a lot, i need info liek that, exactly like that. not just any specific gauge, but any gauge
Old Feb 22, 2003 | 11:55 AM
GZERO's Avatar
no problem, any time.
Now you know why people have those after they spend more than 3K on their engines. Is the only real way to know if everything is working in the proper order
Old Feb 22, 2003 | 02:59 PM
slvrcivic97's Avatar
Good post
Old Feb 22, 2003 | 03:09 PM
Dancing is Forbidden's Avatar
Default Re: why exactly do people get...? (slvrcivic97)
I have an a/f gauge for the light show.
Old Feb 22, 2003 | 10:54 PM
Default Re: why exactly do people get...? (EF9_SiR)
boost gauge= shows the psi a turbo system is running at
vacuum= Measures the lack of pressure that helps to spool turbo(dont quote me)
volt= volts cant really say much
for the most part the gauges describe themselves
Old Feb 22, 2003 | 11:21 PM
Cruiser G's Avatar
The autometer a/f guage isn't really that bad. I wouldn't recommend it for tuning purposes but when your on the throttle and it reads lean, then you know you have a problem. It gives you a general idea of what's going on.
Old Feb 23, 2003 | 08:18 AM
Default Re: why exactly do people get...? (Cruiser G)
it drove me nuts trying to figure it out 3/4 of the lights are always lit so i ordered a techedge wb02
Old Feb 23, 2003 | 08:27 AM
GZERO's Avatar
Default Re: why exactly do people get...? (integra6650)
Good choice
Old Feb 23, 2003 | 09:07 AM
thank you its in the mail as we speak(type)
Old Feb 23, 2003 | 04:46 PM
GZERO's Avatar
i whish i could buy stuff like that and do mods
Old Feb 23, 2003 | 07:21 PM
i dont make too much i just have misaligned priorities.
Old Feb 23, 2003 | 08:53 PM
GZERO's Avatar
sorry, didn't mean to insult, and lol to the misaligned priorities
Old Feb 23, 2003 | 10:44 PM
raene's Avatar
That's a dirty lie... I had my alternator brushes wear out slowly over time, meaning my voltage sloooowly dropped with no 'check battery' warning, until finally in the middle of one fine autocrossing day the car didn't have enough battery voltage to start... a voltmeter would've warned me of this problem
So now I have one
Old Feb 24, 2003 | 07:50 AM
Default Re: why exactly do people get...? (raene)
Nice way to proce the hater wrong. IMO the only useless gauge is the one thats a clock.
[Modified by EF9_SiR, 11:50 AM 2/24/2003]
Old Feb 24, 2003 | 08:22 AM
how was it a lie the meter would have told you how many volts and im not a hater i love my car i know i blow all my money on it and continue to do so
Old Feb 25, 2003 | 08:31 PM
StorminMatt's Avatar
keith
If you are using an oil gauge to tell you when your oil is low, you are doing damage to your engine! Oil gauges do not measure level like a fuel gauge does. Rather, they measure oil pressure. And if you are running your engine with so little oil that the oil pressure is dropping before you add any, you are damaging your engine. The proper thing to do is check your oil from time to time and add oil when needed. The frequency with which you check your oil should depend on oil consumption. In other words, the more oil your engine uses, the more often you should check your oil.
elpiar
Oct 26, 2005 11:21 AM
CivicMike
May 26, 2005 09:34 AM
roydogg
Nov 17, 2003 08:33 PM
itr501
Sep 29, 2001 08:04 PM
