Cam swap
Old Feb 20, 2003 | 11:46 AM
turboHX's Avatar
Default Cam swap
Can I install a D16 Y8 Cam into my D16 Y5 head if not who makes an aftermarket Cam for my Y5 ( stupid HX motor )
[Modified by turboHX, 8:47 PM 2/20/2003]
Old Feb 20, 2003 | 11:49 AM
Spade's Avatar
Default Re: Cam swap (turboHX)
No. The HX even though it is VTEC is actually VTEC-E which stands for Efficiency.
It has only two intake cam lobes and when VTEC is engaged both the intake valves follow the higher intake lobe.
BTW, with an Intake you will match the power of a stock EX.
Adding an EX tranny will make you faster than most EX's.....your weight gives you a serious advantage.
EDIT: I also forgot to mention your torque curve is better.
[Modified by Spade, 12:49 PM 2/20/2003]
Old Feb 20, 2003 | 01:18 PM
turboHX's Avatar
Default Re: Cam swap (Spade)
my problem is this, I have a turbo (t3/t4) setup and I'm only getting 180hp out or the motor. I was told that the cam is the culprit, I want to get atleast 230-250 whp and I think if i change the cam i can achieve that. Therefore I need a performance cam for my motor any IDIAs
D16Cowboy
Apr 26, 2007 01:45 PM
c0nspire
Feb 9, 2006 09:31 AM
Screaming
Jan 30, 2006 08:59 PM
jdmcx
10
May 7, 2004 04:04 PM
spiceisler
Aug 8, 2002 10:58 AM
