B16A Head/GSR Block- Good for Turbo?
Old Feb 20, 2003 | 11:32 AM
RAWB's Avatar
Default B16A Head/GSR Block- Good for Turbo?
Did the SEARCH, and there are a ton of topics, this lowers compression... stick with the GSR head... etc. But none mentioned if this is a good setup with a Turbo. To me, it seems lowing the compression a few points and using the larger combustion chamber of the B16 Head- when coupled some decent tuning would be pretty badass. Is anyone running this setup with FI or seen one? TIA
Old Feb 20, 2003 | 11:50 AM
st00pid's Avatar
Default Re: B16A Head/GSR Block- Good for Turbo? (RAWB)
Ive done it and it ran well.. 11.7 @ 120 @ 13 psi on a 60-1/T3 93 octane.
jason
Old Feb 20, 2003 | 11:51 AM
b18bturbo's Avatar
Default Re: B16A Head/GSR Block- Good for Turbo? (st00pid)
its the poor mans type R it works great..
Old Feb 20, 2003 | 12:42 PM
Turbo SiR's Avatar
Default Re: B16A Head/GSR Block- Good for Turbo? (b18bturbo)
i just bought a gsr bottom end to im gona drop je 9.0-1's in it and crower rods so im hoping it will be bullit proof to 20 psi.
p.s anyone recomend a blowck guard if so which 1 i was thinking inline pro i'd like to hear your thoughts.
Old Feb 20, 2003 | 03:00 PM
RAWB's Avatar
What timing belt are you guys using with this combo, assuming stock deck height on the block and head.
Old Feb 20, 2003 | 03:24 PM
boosted hybrid's Avatar
GSR timing belt. I used this combo before, it works great!
Old Feb 21, 2003 | 09:56 AM
RAWB's Avatar
Default Re: B16A Head/GSR Block- Good for Turbo? (boosted hybrid)
If I use the stock bore of the B18c Block- is there any mods I need to do to the head to make this work? I'm planning on swapping OUT the B16a cams/springs/retainers in favor of GSR cams/valvespring/retainers at the same time. This shouldn't affect any of my valvetrain geometry, right?
Old Feb 21, 2003 | 11:10 AM
BodyKits NW's Avatar
You should be fine. I have a b18c5 block, but with a 2000 Si Head. I just had the head ported and polished. I didn't think it was worth the extra money for the Type-R head.
Old Feb 21, 2003 | 11:47 AM
b18bturbo's Avatar
Default Re: B16A Head/GSR Block- Good for Turbo? (BodyKits NW)
Type R head is way overprices.. just get b16a head port and put nice valve train and yu get pretty much about the same.....
Timing belts are based off the water pump gear. What ever water pump gear oyu have you need that belt.
Old Feb 21, 2003 | 12:22 PM
ricodemus's Avatar
Default Re: B16A Head/GSR Block- Good for Turbo? (Turbo SiR)
I wanted to go with this set-up, but those GSR shortblocks are running too much money. I already have a spare b16, so when I have the money I'm just gonna get that sleeved to 84 mm. Twice the money, but hopefully some piece of mind.
Old Feb 21, 2003 | 12:24 PM
b18bturbo's Avatar
Default Re: B16A Head/GSR Block- Good for Turbo? (ricodemus)
Get 1.7 crank as well drop in that with some nice rods and you should make some plenty power in the 1.6 motor with 84mm bore.
That would be around 1.92 motro
.D!N$E1.
Dec 28, 2004 04:42 PM
spcrxracer
Sep 6, 2004 12:07 AM
92eh3si
Jul 4, 2004 08:53 AM
6ghatch
Mar 1, 2004 10:44 AM
chirp3rd
Jan 20, 2003 12:21 AM
