D series motors
Old Feb 20, 2003 | 11:15 AM
Demonic_Sol93's Avatar
Default D series motors
First off I have a 93 Del Sol S (stock D15 engine). Is it true that ANY D series motors' parts will work with my D15? I am looking for parts and all I can ever find is stuff for the Del Sol Si. Will these parts work on my car? Also, by using parts from a different D motor, will it cause any compatibility issues at any point? Are all D series motors SOHC non-VTEC? Please someone help me out. I will appreciate any help anyone has to offer. Thank you.
[Modified by Demonic_Sol93, 3:17 PM 2/20/2003]
Old Feb 20, 2003 | 11:19 AM
squirrel's Avatar
Default Re: D series motors (Demonic_Sol93)
What kind of parts? If you mean "bolt on" performance parts like header, intake, Cam gear ( if interested, check sig ), Intake manifolds, etc; then yes.
[Modified by squirrel, 8:20 PM 2/20/2003]
Old Feb 20, 2003 | 11:24 AM
Default Re: D series motors (squirrel)
Yeah. I am talking like cams, intake manifolds, cam gears, pistons, anything
Old Feb 20, 2003 | 11:28 AM
squirrel's Avatar
I don't think you can use the D16 cam shafts, but you can use the gears.
I'm not too sure about the block internals. I think the D15 has a smaller stroke, but the same bore (or is it the other way around ). If I am correct you should be able to use the same pistons, but the compression might not be the same. Anyways, There should be pistons for the D15.
oh yeah, you can also use the metal head gaskets for the D16.
[Modified by squirrel, 8:30 PM 2/20/2003]
Old Feb 20, 2003 | 11:39 AM
Spade's Avatar
Read link in sig. for starters.
Old Feb 20, 2003 | 12:09 PM
Default Re: D series motors (Spade)
WOW. that post was great, very informing. thanks for all your advice man.
Old Feb 20, 2003 | 12:10 PM
Spade's Avatar
civicminded93
Jun 19, 2008 07:46 AM
Ls_eg6
Honda Civic (2006 - 2015)
Nov 25, 2006 12:46 PM
Hatchorific
Mar 20, 2006 03:04 PM
skr33t_rac3r
Oct 14, 2004 05:18 PM
