d15 parts on d16
d15 parts on d16
just like title says
if i got a header and cam gear, and tb spacer and intake for my d15 then swapped a d16 it should all bolt up to a d16 too right?
Re: d15 parts on d16 (skr33t_rac3r)
They will all interchange, but the cam gear will be off in it's timing marks. To make it easy on yourself, I'd just wait on the cam gear. But it will bolt to either and work, it will just take some figureing to get the timing correct.
My $.02
My $.02
Re: d15 parts on d16 (civicminded92)
He's right. all series parts are interchangable within that series. For example all d series parts are interchangable with other dseries parts. I don't know much about cam gears, but when you buy a header it usually lists both motors 1.5/1.6
Re: d15 parts on d16 (93civiccxhatch)
Sorry 93civiccxhatch, but they are not "all" interchangeable. I was specifying the particular parts that he listed, not saying that all d series parts will interchange with other d series parts. It's simply not true. There are alot of things that will interchange, which does make it nice when scavengine junkyards for parts.
Re: d15 parts on d16 (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx »</TD></TR><TR><TD CLASS="quote">well wouldn't a ex piston not fit a dx piston because of the .1 liter difference, or does that not matter?</TD></TR></TABLE>
they would fit, actually the dx piston raised compression i believe
civicminded93
06-19-2008 07:46 AM
