does this block need to be sleeved?
Old Feb 20, 2003 | 08:02 AM
black-hatch's Avatar
Default does this block need to be sleeved?
Do u think this block could just be bord over or will it need sleeves its a itr block thx
Old Feb 20, 2003 | 08:11 AM
qtiger's Avatar
Default Re: does this block need to be sleeved? (black-hatch)
Well all the reflections from the oil make it pretty hard to tell... I don't see any deep gouges though.
You'll have to take it into a machine shop for a final word though... those could be scratches or reflections from the slag of a piston.
You lean out running nitrous or what?
Old Feb 20, 2003 | 08:13 AM
delslow94's Avatar
Default Re: does this block need to be sleeved? (qtiger)
pull the pistons and rods and check to see how true the bore is of the cylendar. if its the same measurement, im assuming 81mm, at the bottom or top then you should be ok.
Old Feb 20, 2003 | 08:23 AM
Default Re: does this block need to be sleeved? (delslow94)
well the kid who has said that a valve retainer broke and the valve fell into the cylinder and here is some more pics
Old Feb 20, 2003 | 08:39 AM
qtiger's Avatar
There's always the possibility of scratches in the cylinder wall too deep to fix with just a bore.
Black-hatch, pull the pistons, clean the oil off the cylinders, and take some more pictures.
Old Feb 20, 2003 | 09:16 AM
itr537's Avatar
that happened to my block...had it bored to try and fix but didnt leave enough thickness on cylinder wall...so getting the one re sleeved better to be safe than sorry....time to go oversize...81.5mm.....
Old Feb 20, 2003 | 11:09 AM
TimoneX's Avatar
New User
Default Re: does this block need to be sleeved? (itr537)
I can't really tell how deep the damage is from those pics. There's another option you may not have considered. Darton makes single replacements sleeves for around $30. You could have a machine shop do that for $50-$100ish. If there's damage to more than one, I'd send it to golden eagle and have it sleeved. If you do that though go all out and get 85-86mm pistons. Might as well make the $$$ spent worthwhile. Good luck.
GT500FTW
Nov 3, 2014 02:32 PM
hYbRid_Eg6
Oct 26, 2010 04:57 PM
blackccoupe
Oct 14, 2010 10:28 PM
2LiterTurboSeR
Jan 9, 2010 02:29 PM
No_Limits_Accord
Jan 9, 2010 09:39 AM
