is it safe to use less more layers of head gaskets
Old Feb 20, 2003 | 07:39 AM
NightHawkC5's Avatar
Default is it safe to use less more layers of head gaskets
I want to raise or lower my compression depending on what pistons i get so is that safe and how much does it lower or raise the compression if u remove or add a layer
Old Feb 20, 2003 | 08:01 AM
Spade's Avatar
Default Re: is it safe to use less more layers of head gaskets (NightHawkC5)
Just use the Y8 gasket and get the pistons made to the compression you want.
However, no, different layer gaskets will not harm your performance.
Unless you get crazy like 13:1 comp pistons on a 3 layer gasket then drop in a 1 layer and your tuning isn't right.
b00stedOne
Jul 28, 2014 09:56 AM
JAMSiR
May 26, 2010 08:24 AM
kazino42
May 22, 2005 02:41 PM
vtekthis
Nov 2, 2004 07:17 PM
