Has anyone ever had this problem??!?!?!
Old Feb 19, 2003 | 06:22 PM
jdmcrx1's Avatar
Default Has anyone ever had this problem??!?!?!
I have a 91 dx body with all 89 si wires and motor....i replaced the thermostat, the relay for the fan anf checked all the wires....But my fan still doesn't kick on...? it did when i first put the motor in though...i am stuck and don't want it to overheat please help any way you guys can!!... Thanks for all your help. also I have some crx parts if anyone wants them..
Tony 402-208-4061 for info on parts, call
Old Feb 19, 2003 | 06:25 PM
Mefain's Avatar
Default Re: Has anyone ever had this problem??!?!?! (jdmcrx1)
i experienced that problem myself....turned out the actual motor in the fan was bad...replaced it for like $35....hope that helps you
Old Feb 19, 2003 | 06:26 PM
XEF-9X's Avatar
Id like to know too. Ive had this probelm ever since my zc swap. ( i have a b16 now) it happened after i took my A/C out
Old Feb 19, 2003 | 07:14 PM
jdmcrx1's Avatar
last i checked the motor in it was good
my next thing is the thermoswitch....any ideas on that?
Thanx
Tony
Old Feb 19, 2003 | 07:29 PM
spettinger's Avatar
please briefly state the problem in the title of your post, this will help you get responses.
Old Feb 19, 2003 | 08:45 PM
RCautoworks's Avatar
Default Re: Has anyone ever had this problem??!?!?! (2ndhandCRX)
I don't think my fine has turned on since my swap either, and I know my fan is good cause I tested it. Once you know your fan works, check the fuse and then the sensor.
Old Feb 20, 2003 | 09:11 AM
jdmcrx1's Avatar
Default Re: Has anyone ever had this problem??!?!?! (90blackcrx)
Ok... for those of you who can't understand it like 2ndhandcrx, ...my fan does not work!... I replaced the relay tested the fan and followed the wires.no power...If that is not descript enough ten i don't know what is.. Please, if you have no input other than criticism, don't post! Thank you and I will do my best to help anyone out who needs it as well...
Tony then motor in it is good, so is the relay, the fuse and the wires, would it be the thermo switch? thanks guys
Old Feb 20, 2003 | 09:41 AM
Mugen Dom's Avatar
i was gonna say the switch also the one that actually bolts to the engine
Bender C/F
Feb 12, 2010 07:46 PM
phelpsj2
Jul 24, 2009 08:17 AM
efjones9
Dec 17, 2008 09:01 AM
beerex
Apr 7, 2006 10:16 PM
THugluv423
Apr 19, 2005 06:38 PM
