hondata s200 problems(help)
after the last update 3.2 the check now is on whit the #1code(oxigen sensor) and i install a s200 NA to a friend and the check is on and it has a #1 code to.
is it my oxigen sensor and he's or is an upgrade problem.please help me.
trying to say???hardest post to read, EVER!!!
have you tried switching O2 sensors?
What car is this in?
I rarely see anyone get a code 1 with 92+ Honda's. It's usually been a code 10 for IAT. I thought they usually got a code 41 for the heated primary O2.
[Modified by badCRX, 9:17 AM 2/20/2003]
I'd say its your oxygen sensor, they do go bad. Call hondata today and ask one of their employees. Their customer service is one of the things you are paying for...
Si quisiera hablar español lo hibiese hecho.
Cual la necesidad del comentario?
as far as your hondata problem, why not just call or email them directly? they have an account on here that you could probably send a PM to and find out quick. good luck.
Last night I got the same code. I am running an FJO wide band. I know it isn't going bad as it is new. With stage 4 I never had this happen. With the s200 upgrade this has happened to me once. I'd like to know what Hondata thinks also.
gracias por la correccion pero cuando tecleas incomodo te faltan unas cuantas letras.
About the e-mail i've sent some mails but the server of hondata is down and the massage is return whit this note:
The e-mail account does not exist at the organization this message
Does the code go away if you turn off the key and turn the car back on, and does the code only come on when decelerating?
Also do you have the stock O2 plugged in?
[Modified by Spunkster, 9:44 AM 2/21/2003]
You can reset the code with the hondalogger or turning the car off. And yes it does come on with deceleration. Do you know what the problem is? I'll call Hondata today.
TypeRguy97
Oct 25, 2006 09:55 PM
turbo95eg6
Jul 2, 2005 08:27 PM
