clutch fluid low...
what does this mean? I opened up the cap and its down so that the little circular plug thingey was 2 or 3 mm from touching the sides... i put some more in there. Does this thing sorta just happen or is it something i should look more into?
I have an ACT XTSS and fidanza flywheel if that makes a difference.
check the area under the dash where the pedal going through the firewall (aka clutch master cylinder) When they get old and worn out, they leak and most of the time they leak inside the car and onto the carpet. Mine did it at 100K and I replaced it myself. It's not a difficult job.
i did notice when i was cleaning my car that there was some grease or oil stain on the carpet near the pedal. I didn't even think to relate it to that..
thanks a bunch,
ryan
thanks a bunch,
ryan
yep that will do it
david236kEG
23
Jan 28, 2009 03:34 PM
