zc swap Q's hf crx
i have a hf and i am putting a zc in it,i was wanting to know what i would have to do to make it work if i was buying a zc znd zc tranny,ex what ecu, axles,wire harness, and do all of the mounds fit up?
you need crx si axles,89 integra 5spd ecu,crx si tranny,crx si nuckles.then your stock wire harness and mounts should work on that motor.
FYI: zc motors dont run 13s n/a you should go Bseries my dohc zc ran low 15s
p.s. no more shiftlight on gauge cluster
[Modified by ZC_CRX, 9:56 AM 2/19/2003]
You can use the CRX Si tranny. This requires Crx Si axels and hubs.
Go with the ECU that came witht he ZC engine(PM7). As for the axles....HF axles WILL WORK with a HF car and a SI trany. Don't let anyone tell you thay won't.
Something to think about is that the SI hubs and axles are bigger then the HF's. So if you are going nos, turbo etc....it might be a good idea to get SI items...plus the SI has bigger brakes!!!
h22_crx
Aug 30, 2005 05:59 AM
