pics of my header guard (skidplate)
Old Feb 18, 2003 | 05:10 PM
johnzm's Avatar
Default pics of my header guard (skidplate)
i dunno if u can see in the first pic (this lcd sucks) theres a ton of scrape marks on my driveway from this thing. and from looking at how close it is to the header, i bet that the header wulod be leaving the marks if the skidplate wasnt there
[Modified by johnzm, 3:22 AM 2/19/2003]
Old Feb 18, 2003 | 05:16 PM
goforbroke's Avatar
MEAT PATTY
Default Re: pics of my header guard (johnzm)
Looks like it works for its purpose. I'd buy one if I didn't have this peice of **** DC header.
Old Feb 18, 2003 | 05:37 PM
johnzm's Avatar
Default Re: pics of my header guard (goforbroke)
actually, that was custom made. it is a DC header on there a JDM 4-1. that guard is welded to the front x member. i have hit it HARD and it hasnt bent yet, but has dropped showers of sparks out the back of the car
Old Feb 18, 2003 | 05:43 PM
crxaddikt's Avatar
so, your basically saying, if i get a a DC header (which i plan on getting), it sits so low that it hits or scrapes? (on 90si)?, cause if i get one, i would'nt want it hitting when i go up driveways and such.
i did'nt know if your car is lowered or not, cause maybe thats why the header sits lower? just wondering
Old Feb 18, 2003 | 05:51 PM
johnzm's Avatar
Default Re: pics of my header guard (crxaddikt)
i had the car MUCH lower. i had to raise it because the header sits so low. i DO NOT reccomend this header on a b16, only a b18c
here is a pic of my cars ride height.
the front had to be raised ~ 1 inch and i still scrape on everything
Old Feb 18, 2003 | 06:01 PM
escocrx's Avatar
yea my **** so low it scrapes everywhere. the header downpipe is basically destroyed
Old Feb 18, 2003 | 08:53 PM
PsychoSiRex's Avatar
Why not us the DC jdm header on a B16 motor
Old Feb 18, 2003 | 10:57 PM
philly-O's Avatar
Default Re: pics of my header guard (PsychoSiRex)
where does it mount to other than the crossmember? can you get a better pic of the under side of the guard?
Old Feb 19, 2003 | 05:57 AM
silverCRXTC's Avatar
Default Re: pics of my header guard (peichie)
damb i need one of those, i have adc gsr header and im tucking my 14s im so low. i need to make one of those cause i scrape like a chick with braces
Old Feb 19, 2003 | 06:18 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: pics of my header guard (silverCRXTC)
Did you have to modify the header at all for it to fit? Im putting an LS in my CRX using HASports...are there any headers that will fit it without modification? If i buy a header i dont want to cut and reweld it. Thanks.
Sean
Old Feb 19, 2003 | 06:54 AM
UncleBen'sRacing's Avatar
Default Re: pics of my header guard (sCeRaXn)
boys and girls the cheapest way to not destroy headers is to not be that low!.... i mean as long as you have a good suspension and no body lean you dont need to be that low here is my car i have TEINS on it and it isnt that low, but i always come in top 10 at autoXs with 50 Plus people in class.....and i dont know how to drive
Old Feb 19, 2003 | 07:00 AM
Maddhatcher's Avatar
Default Re: pics of my header guard (AllMotorEF9)
lets see that pic
Old Feb 19, 2003 | 05:04 PM
johnzm's Avatar
donot be a hater u KNOW my car isint low. i got the fronts raised up so high the springs are binding, so its near impossible to raise it anymore
for all the Q's.
the guard is welded to the front x member. ill try to get some better pics soon.
the only thing that required modification was the x member, and he notched it with a plasma cutter to make the ehder fit well. the piece is a boxed in steel pieces that were cut to fit the x member. its actually 4 pieces of metal, using a reinforcememnt piece.
if any of you are really interested in getting one of these made for your car, you can give my fabricator a call. he does AWESOME work
http://lockracewrks.com/
ask for joey
Old Feb 19, 2003 | 05:11 PM
johnzm's Avatar
oh yea, these DC JDM 4-1 is made for the taller block of the b18c, so it sits alot lower on a b16 (less deck height) i can stick my finger between the header and the oil pan, im sure its the same way with a JDM ITR 4-1, but from what ive seen, the dc will hang lower becasue of how the tubes are paired
BTW- stay tuned. ill get more pics tomorrow after work
[Modified by johnzm, 2:20 AM 2/20/2003]
Old Feb 20, 2003 | 01:52 PM
johnzm's Avatar
aihgt like i said, more pics.
and for reference, this is ho low my car is...
Old Feb 20, 2003 | 02:08 PM
johnzm's Avatar
got a couple more pics. i would discourage using this header on a b16 unless u have something like this on your car...
Old Feb 20, 2003 | 02:31 PM
mannyman's Avatar
El Veterano de Sur Califas
thats a nice *** skid plate....how much did it cost???
Old Feb 20, 2003 | 02:50 PM
johnzm's Avatar
Default Re: pics of my header guard (mannyman)
ask for joey
Old Feb 20, 2003 | 02:52 PM
15psi of fun's Avatar
you are nuts that is way to low i fucked up a header and it wasn't even that low.
Old Feb 20, 2003 | 03:10 PM
johnzm's Avatar
Default Re: pics of my header guard (EFrollingout)
actually that header is in pratically perfect condition, as you can see. when i hit something that guard hitting the ground pops the car back up so quick that nothing gets damaged.
JDMDelSol4
Apr 6, 2009 07:29 AM
tempsohc
Nov 18, 2007 10:01 AM
broketuner-Sol_Si
Mar 20, 2006 10:57 PM
germanEE8
Nov 20, 2003 11:19 PM
3700 Vtec
Mar 24, 2003 07:38 PM
