Will it run high 10's?
Ok my friend has a 90 crx bored out gsr block with a b16 head its has some where around a 16:1 compression, its basically fully built, welded diff, fully gutted going to weigh about 1700 with him in it, he going to make about 230whp all motor w/ race gas. He says his setup is good for high 10's. Do you really think he can pull that with about 230whp in a stripped crx "1700 w/ driver"?
no, there are some people making 230 and the car weights about 1500 with driver doesn't even hit that time. i think you're going to need some work on the car and the motor should over 240 atleast to pull the high 10s.
16:1 compression should make over 230 PERIOD. there are people running that compression and they are making about 250+ and some people are running about 13.5:1 compression and they are close making 250 already.
[Modified by Dual Cams, 4:03 PM 2/18/2003]
Ive seen people with only 250hp(dunno the tq)only hit low to mid 12's with stripped interior..No 10's for you.Like Evil said maybe 11's.If your a good driver.
with the right suspension/tranny set up on that weight crx, 230 to the wheels, and wheelie(traction bars for you PC people) bars, he will run low 11's. like 11.20-11.30. no better.
I ran 10.99 about 7 to 8 months ago and I had the same 260 WHP that I have now,Until I decided to with a smaller slick I finally ran 10.78 And my car has always weight 1600 lbs with driver.
Paul
At 1740 lbs and 237 whp our best was a 11.53 @ 116mph, and thats with a good driver without wheelie bars!
[Modified by 10s_ALLMotor, 5:12 PM 2/18/2003]
i saw javier's car run 10.78 at battle in november.. strangely i tried going back to running a smaller slick and it also worked for me... i was running 11.3 11.4s with a 24.5 tire and went to a 11.2 11.3 with a 22/9 i notice alot of cars switching back and going just as fast or faster.....
I was running 24.5/7/13 and I decided to try 22/9/13 and I ended with a better 60 foot and a better ET. My gearing it's always been stock, I have a jdm 16 tranny with a 4.78 final drive. I'm thinking on putting a 4.9 final dive but I know that I will gear out.
