Will it run high 10's?
Old Feb 18, 2003 | 11:49 AM
Project92Hatch's Avatar
Default Will it run high 10's?
Ok my friend has a 90 crx bored out gsr block with a b16 head its has some where around a 16:1 compression, its basically fully built, welded diff, fully gutted going to weigh about 1700 with him in it, he going to make about 230whp all motor w/ race gas. He says his setup is good for high 10's. Do you really think he can pull that with about 230whp in a stripped crx "1700 w/ driver"?
Old Feb 18, 2003 | 12:02 PM
Dual Cams's Avatar
Default Re: Will it run high 10's? (Project92Hatch)
no, there are some people making 230 and the car weights about 1500 with driver doesn't even hit that time. i think you're going to need some work on the car and the motor should over 240 atleast to pull the high 10s.
16:1 compression should make over 230 PERIOD. there are people running that compression and they are making about 250+ and some people are running about 13.5:1 compression and they are close making 250 already.
[Modified by Dual Cams, 4:03 PM 2/18/2003]
Old Feb 18, 2003 | 01:14 PM
Evil DOHC's Avatar
Default Re: Will it run high 10's? (Dual Cams)
I would say solid mid 11 second car.
EVIL
Old Feb 18, 2003 | 01:36 PM
T3's Avatar
T3
Default Re: Will it run high 10's? (Evil GS-R)
Ive seen people with only 250hp(dunno the tq)only hit low to mid 12's with stripped interior..No 10's for you.Like Evil said maybe 11's.If your a good driver.
Old Feb 18, 2003 | 02:09 PM
jinxproof99's Avatar
New User
Default Re: Will it run high 10's? (T3)
with the right suspension/tranny set up on that weight crx, 230 to the wheels, and wheelie(traction bars for you PC people) bars, he will run low 11's. like 11.20-11.30. no better.
Big_Mike's Avatar
At 1740 lbs and 237 whp our best was a 11.53 @ 116mph, and thats with a good driver without wheelie bars!
[Modified by 10s_ALLMotor, 5:12 PM 2/18/2003]
Old Feb 18, 2003 | 02:14 PM
New User
Default Re: Will it run high 10's? (10s_ALLMotor)
my friends car went 11.40's with around 220 to the wheels and 1700-1800 lbs. 11.50's all day long.
Old Feb 18, 2003 | 02:19 PM
allmotorhatch's Avatar
Default Re: Will it run high 10's? (jinxproof99)
10's all motor- Dou you still have that spool
Old Feb 18, 2003 | 06:35 PM
J2turbo21's Avatar
Default Re: Will it run high 10's? (allmotorhatch)
What would you hit with 230whp and a full interior 92 civic hb?
Old Feb 18, 2003 | 07:10 PM
Javier's Avatar
I ran 10.99 about 7 to 8 months ago and I had the same 260 WHP that I have now,Until I decided to with a smaller slick I finally ran 10.78 And my car has always weight 1600 lbs with driver.
Old Feb 18, 2003 | 07:26 PM
T3's Avatar
T3
Default Re: Will it run high 10's? (JavierSinisterERE)
What engine,turbo and what was the psi set at?
Paul
Old Feb 18, 2003 | 07:52 PM
Big_Mike's Avatar
yes I still have everything in my sig
Old Feb 18, 2003 | 08:21 PM
tony1's Avatar
Good driver, huh? haha, just messin with you...
Old Feb 18, 2003 | 08:32 PM
ninesecrx's Avatar
Default Re: Will it run high 10's? (tony1)
I think maybe your combo might have to much comp. and its fighting against you and thats why the hp is now...
Old Feb 18, 2003 | 09:20 PM
Javier's Avatar
My car has always been All Motor and the engine is bult by Erick's Racing.
Old Feb 18, 2003 | 09:22 PM
J2turbo21's Avatar
do mind sharing your setup with us?
Old Feb 18, 2003 | 09:55 PM
Javier's Avatar
Default Re: Will it run high 10's? (J2turbo21)
GSR motor with Erick's 2 liter setup.
Old Feb 19, 2003 | 04:07 PM
How does that pro drive spool work and what shape is it in.
Old Feb 20, 2003 | 01:19 PM
4piston's Avatar
Javier
Did you say that you ran the 10.78 on a smaller slick? I think I read that correctly. What size did you drop to?
Old Feb 20, 2003 | 11:30 PM
super iyee's Avatar
Default Re: Will it run high 10's? (4piston)
i saw javier's car run 10.78 at battle in november.. strangely i tried going back to running a smaller slick and it also worked for me... i was running 11.3 11.4s with a 24.5 tire and went to a 11.2 11.3 with a 22/9 i notice alot of cars switching back and going just as fast or faster.....
Old Feb 21, 2003 | 01:46 AM
Dual Cams's Avatar
Default Re: Will it run high 10's? (OAKLANDALLMOTOR)
you were running 24.5 by 7.5 or 8s?
Old Feb 21, 2003 | 07:12 AM
autoraceparts.com's Avatar
Very impressive! Do you run aftermarket trans gears or stock gears? What was the weight of your car when you ran 10.78?
Old Feb 21, 2003 | 08:10 AM
All Motor Rex's Avatar
Yea, with 16:1 I would think that it should make over 230. I recently read about a 11.5:1 compression motor making 240+
Old Feb 21, 2003 | 08:43 AM
Javier's Avatar
I was running 24.5/7/13 and I decided to try 22/9/13 and I ended with a better 60 foot and a better ET. My gearing it's always been stock, I have a jdm 16 tranny with a 4.78 final drive. I'm thinking on putting a 4.9 final dive but I know that I will gear out.
Old Feb 21, 2003 | 10:24 AM
google's Avatar
good thread
