Compustar alarm won't auto start
this started last week all of sudden the auto start feature stopped working, it beeps 3 times and nothing happens does anyone have that problem?
any help is apreciated
I could be many things.....is your hood open? Trunk open? (if the installer hooked this up)
Your Valet switch could be on if you have the the older version. The newer version doesnt have a physical switch. Its built into the remote.
If you have a stick shift vehicle, did you set up the "reservation mode?"
I need more details to diagnose.
hand comand i was just curios if compustar mad a stand alone remote start for manual cars i want to add remote start to alarm i have now
You might have to reset the reserve mode if you have a manual trans. go in car and reset the reserve mode. check your manual
ok I cheked a few things all the doors were closed(no power locks)
, trunk was properly closed, hood closed etc.... before I remove the key I put it on the hand brake leave it on neutral and the car stays on until I close the door which is whats supposed to happen...
now about the switch the installer used a switch I made to disable my blue signal lights that I have on my M3 mirrors(ricey) but anyway I've played around with the swith but it doesn't make a difference
btw I have the older style (black) pager...
[Modified by metal-x, 8:39 PM 2/18/2003]
, trunk was properly closed, hood closed etc.... before I remove the key I put it on the hand brake leave it on neutral and the car stays on until I close the door which is whats supposed to happen...now about the switch the installer used a switch I made to disable my blue signal lights that I have on my M3 mirrors(ricey) but anyway I've played around with the swith but it doesn't make a difference
. But there should be a valet switch other than your ricey switch
somewhere. When you find it try it on then try it off.
The compstar should give you a code by a number of parking light flashes after the original three. (ie...flashes 3 times and then 1 more.....the unit is sensing that the engine is running) It should flash from 1 to 6 times with each # being a different problem. If you post that # on here then either myself or HandCommand should be able to pin-point the trouble area.
yea he's correct 3 beeps is a code, just because your door is closed doesn't mean the alarm sees it as being closed, maybe the wire came loose. if they are negative trigger, then it needs to see 12v when the door is closed
1 Engine On
2 Key On
3 Door Open
4 Trunk Open
5 Brake On
6 Hood Open
7 Reservation Off (Manual Transmission Only)
1 Engine On
2 Key On
3 Door Open
4 Trunk Open
5 Brake On
6 Hood Open
thanks all for the tips
the three beeps meant then the door was opened??
thats impossible I cheked that... ok this is what I did and I duno if the install is messed up but basically what worked for me is I have a fog light switch that I no longer use and all I did is switch it on and now it autostarts its weird I'll have to talk to the installer about it doesn't seem right
Didn't I tell you it was a switch somewhere cause I was doin the same thing for 2 days cursing and yellin at the stupid alarm til I called the installer and he told me about the valet on or off switch and the reserve mode. Now you can enjoy the alarm
[QUOTE=
1 Engine On
2 Key On
3 Door Open
4 Trunk Open
5 Brake On
6 Hood Open
7 Reservation Off (Manual Transmission Only)[/QUOTE]
sorry to raise this old posting but i am having this same problem with my Jazz Pager alarm, everything else works fine except the remote start, now i was wondering what do you guys mean by Resevation off???? Can someone explain that to me??
1 Engine On
2 Key On
3 Door Open
4 Trunk Open
5 Brake On
6 Hood Open
JDMCRX
Audio / Security / Video
May 27, 2009 12:42 PM
SPORT INJECTION
11
Nov 2, 2002 07:02 AM
