Little problem, need opinions...
Old Feb 18, 2003 | 09:28 AM
2001TypeR's Avatar
Default Little problem, need opinions...
Well last nite we installed my Injen CAI in my ITR, but it was a cold nite and when i reinstalled the Tower strut brace bar i snapped one of the 4 bolts (not the bolt itself but the thing is screwed on to) by accident. Can it be fixed, or it it not a big deal? What should i do?
Old Feb 18, 2003 | 09:29 AM
Reid's Avatar
Global Moderator
Default Re: Little problem, need opinions... (2001TypeR)
Pound out the stud and replace it.
Old Feb 18, 2003 | 09:31 AM
2001TypeR's Avatar
Default Re: Little problem, need opinions... (Reid)
Ok so its not too hard since its not part of the metal its on right? Ok thanks alot
Old Feb 18, 2003 | 09:33 AM
Reid's Avatar
Global Moderator
It's a stud, just pound it out. It is not attached to the sheetmetal.
Then if need be, you can draw in the new stud by tightening down the nut.
Old Feb 18, 2003 | 12:13 PM
MARC P's Avatar
YOu can just use a 12mm bolt and nut when you pound out the old one.
Old Feb 18, 2003 | 03:27 PM
2001TypeR's Avatar
Default Re: Little problem, need opinions... (MARC P)
But if i hammer it through, won't the new stud not fit because the hole will be bigger, or will the stud's threads break instead of the hole getting bigger?
[Modified by 2001TypeR, 6:29 AM 2/19/2003]
Old Feb 18, 2003 | 03:37 PM
Reid's Avatar
Global Moderator
The threaded end of the stud is not bigger than the hole.
If it were, how do you think Honda put the stud through the hole?
ilu
10
Mar 31, 2007 04:35 PM
typeR#0427
Jul 10, 2006 11:35 PM
el negro
Suspension & Brakes
May 30, 2006 12:21 PM
spock_rocker
21
May 20, 2004 04:56 PM
weakGOODJunKieS.com
Mar 9, 2003 02:34 PM
