How to bleed water system ?
usually improper coolant levels will cause the engine to idle up and down. so check coolant level. but for the 15-20 fix, change the thermostat. and gasket if that does the trick good, but if it comes back id say you may want to look at a new head gasket cause coolant leaking elsewhere...
To answer your question... If you follow the upper radiator hose to the engine you will see a 10mm bolt around a stud with a small hole in it. You loosen this to bleed the air from the system until the coolant flows steadily. Don't forget to replenish the coolant in the overflow recovery bottle.
I had air in my coolant after replacing the radiator and as a lazy fix to stop a surging idle I just turn on the car and let it warm up with the radiator cap off. This let bubbles come to the surface and fixed my surging idle.
4doorpowa
Jan 24, 2011 12:50 PM
SeanK325
Jun 22, 2010 02:52 PM
