thrust washer question
When installing the thrust washer, do the grooves face towards each other or away from each other??
I did a seach and all I came up with is: "the grooves facing toward the crank." (which I don't quite understand
Here's the original thread: https://honda-tech.com/zerothread?id=260947
)Here's the original thread: https://honda-tech.com/zerothread?id=260947
yes, I know the grooves face "towards the crank" already. Maybe I should re-state my question:
There are 2 thrust washers. Each thrust washer has 2 sides (1 grooved, 1 non-grooved). Now when the thrust washers are in place, will the grooves on one thrust washer be facing the the grooves on the other thrust washer, or not?
when the thrust washer(s) are installed, the smooth side of the thrust washer will go against the block(inward), and the grooved side will go against the thrust surface on the crank(outward). when both are installed, the groove side will face away from each other
juntuned
57
Sep 29, 2006 05:33 PM
